Old 01-08-2006, 02:19 PM
GvEman's Avatar
GvEman GvEman is offline
That truck is so amazing and so brutal! Cant take my eyes of it...
i should have used these Billet
or these
Old 01-08-2006, 07:52 PM
JamesJ JamesJ is offline
Originally Posted by ironworks
The truck is a chopped 50 chevy on a full custom chassis. I don't have a pics because it is torn down to powder coat and paint. There are a few early build up pics on the hamb. We should have it back in one oile by march. It is chopped 8 inches and has wide whites and a crazy small block. I will look for pics. Here are some links. I will try for more.
Rodger
http://www.jalopyjournal.com/forum/s...ghlight=Yunque
I did not think anyone else on this board also was on the HAMB ! !
James J.
Old 01-08-2006, 10:28 PM
Roger Poirier's Avatar
Roger Poirier Roger Poirier is offline
Originally Posted by XcYZ
Some new pics.
Here are the rest.
I guess the rest of us guys will just have to keep dreaming.....
R.P.
official car name - DELIVERANCE
Old 01-16-2006, 12:50 PM
ironworks's Avatar
Default Well I ordered the wheels
I ordered the Muroc wheels form Budnik and They said 6-8 weeks for the wheels. I ordered 22 x 10 with 6" back space and 20 x 8.5 with 5.75 back space. I'm waiting on the wheels to set it on the ground. I'm ready to lengthen the torque tube and I should have the bed sides made by friday.
http://www.budnikwheels.com/roadwhee...3&pid=746&pg=4
Rodger
Old 01-16-2006, 02:44 PM
B Schein's Avatar
B Schein B Schein is offline
Please elaborate on how you plane to length the torque tube. This has always bin of interest to me.
Brian
Old 01-17-2006, 07:31 AM
TravisB TravisB is offline
good choice on the wheels that will look nice
Kenny Davis Hot Rods
Old 01-17-2006, 03:33 PM
ironworks's Avatar
Default Lengthen the torque tube
Well The torque tube is actually a tube with a drive shaft in it with no U joints. I cut the tube into 2 pieces in my big band saw then I chucked each end up in the lathe to cut the welded tube out of the ends. then i went to my steel supply house and ordered 8 ft of 5" 3/13 wall aluminum which is the same size as the old tube. Then I will mock up the pieces in the car to get a true length then bolt everything in the car and square the pieces and slowly weld the ends to the tube. Then I will send out the driveshaft to be lengthened.
Rodger
Old 01-27-2006, 03:07 PM
ironworks's Avatar
Default I got the brakes
Well I got a call From Wilwood this morning and the brakes are a go, they made me a sweet deal. I got the 14" ones with the red calipers. They are all drilled and sloted and all that good stuff. I got 6 piston fronts and 4 piston rear. They should be here in about 3-4 weeks.
Rodger
