View Poll Results: AL or Steel flywheel
AL 19 46.34%
Steel 22 53.66%
Voters: 41. You may not vote on this poll
Old 03-12-2013, 03:57 PM
randy randy is offline
Originally Posted by Blake Foster View Post
My Nova has an Aluminum McLoed flywheel and an RST clutch. and i drive it on the street!! no issues, it did take a while to get to the point of not stalling it every time i let the clutch out, and the smell of the organic clutch is not that plesent. but it sure revs fast!!! there is some trade off but i would never put a steel fw in a car that is going on the track, trust me you get used to it in a hurry.
Greg you can't beleve everything you read on the internet you know!!
" You cant post anything on the internet thats not true"
" where did you hear that"
" on the internet"
Old 03-15-2013, 04:25 PM
sik68's Avatar
sik68 sik68 is offline
Aluminum flywheel is the best thing about my car! Makes it feel way faster and sound way meaner than it really is. The whole car just gets more visceral in the lower gears.
I start off in 2nd gear (1.98*3.73 = 7.39) all the time no issues, just a little more finesse is needed I suppose.
Another benefit...in a (God forbid) kaboom in a bellhousing, a 15lb aluminum flywheel is much safer than a 30+ lb steel one.
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 03-15-2013, 09:31 PM
I put one behind my 666hp ZL-1 489 and enjoyed it thoroughly. Mine was 14 lbs. I could take off without even blipping the throttle. It just ate it up. It revved like a short stroke small block all the way to 6800. It made rev matching way easier.
The compromise, because there are always compromises: It made my tko600 even harder to shift. It would also start to buck 200-300 rpm sooner in a tall gear for the speed.
I'd do it again except behind a t56 and rev it to 7200.
Old 03-22-2013, 03:43 PM
garickman garickman is offline
There is some pretty cool info in this article about the effects of aluminum vs. steel flywheel. Kind of long but worth the read
http://www.popularhotrodding.com/fea...e/viewall.html
Greg
Old 03-25-2013, 11:11 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Good information in that article .... I am running a 12 lb aluminum flywheel on my 427" LS engine. It does take just a bit more RPM when starting out but barely noticeable.... still very easy to drive on the street in traffic. I like the way the engine responds and feels with the lighter aluminum flywheel.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 03-26-2013, 12:35 AM
Flash68's Avatar
Flash68 Flash68 is offline
I like that point. Makes me feel even mo betta about my 7#er.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 03-28-2013, 12:27 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
Doesn't the reciprocating assembly in an FE weigh about as much as a complete SBC?
It will be fine with aluminum just slightly more throttle input when pulling off from a stop.
Make sure you get a good flywheel if you go with aluminum. I've been in some cars with cheapo budget alum flywheels and they would flex with RPM. (You could push the clutch to the floor while in gear and if you revved it over 6000rpm the car would lunge forward). Bolt the same clutch to a good flywheel (or steel) and the problem disappeared.
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700. 95 F355. 96 Carrera 4S. 59 Cadillac series 62 convertible.
