Old 03-12-2011, 01:10 PM
You always make me feel better about my hot rod. Thanks for sharing all the tweaks and hurdles.
Old 03-13-2011, 09:54 AM
James OLC's Avatar
Some more pictures from Carl...
Here is the Voltage Controller and Signal Conditioner mounted on a handy little plate that David "whipped up"
and installed in the car as close to the battery as possible
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 03-13-2011, 09:56 AM
James OLC's Avatar
The complete Ricks Stainless tank with the VaporWorx conversion and electronics
The tank before
after
and installed
James
1969 Camaro - Dusty
Old 03-13-2011, 06:33 PM
Originally Posted by James OLC View Post
Anyways…
Fired up the mill and opened up the base of the LCA to clear the shock body…
James -- How many flutes on that end mill?
Looks like TWO... but I can't tell. If it's a two it's for ALUMINUM and a 4 flute mill is for steel...
Since I can't tell - I'm not making a "judgement"... and a two will cut the material... so doesn't really make any difference.
Great looking work and a great looking solution!
Old 03-14-2011, 12:39 PM
onevoice onevoice is offline
James
I thought you were using Speed tech high clearance arms, and that they were only were available in a coilover configuration. The arms in the pictures have a normal looking spring cup. Are you only using upper high clearance arms? Do they only make upper high clearance arms? A few more pictures of your setup with a wheel installed and the tight clearance spots shown would be greatly appreciated.
Old 03-28-2011, 11:59 AM
James OLC's Avatar
We'll have some more pictures later this week but in the mean time, Muscle Car John was over at the Pozzi's and snapped some pictures while the new Baer 6R brakes were being installed.
James
1969 Camaro - Dusty
Old 03-28-2011, 12:00 PM
James OLC's Avatar
James
1969 Camaro - Dusty
James OLC's Avatar
And the new HRE Comp 93 wheels... 18x9 in the front and 19x12 in the back
Flat black centers
Brushed hoops
James
1969 Camaro - Dusty
Old 03-28-2011, 12:16 PM
Old 03-28-2011, 03:49 PM
buickfunnycar.com's Avatar
Wink Forgot one...
LOL
www.buickfunnycar.com
