The TEC3 is a very high end system. It is extremely configurable: sequential, TBI, bank to bank, staged...It also contains 60 (-2) crank trigger teeth which is every 6 degrees compared to something like an MSD which has a magnetic trigger every 90 degrees. It then converts this to signal to angular momentum versus the not as accurate time-based interpolation. For most systems this is probably overkill, but it works. It also has additional controls for boost, four stage retard for nitrous, shift lights, water pumps, fans, torque converters, etc. Quite a bit of goodies. Plus the ignition utilizes multi coil packs. This is based on info I compiled during my due dilligence
for EFI systems FWIW.
