Old 03-24-2011, 09:31 PM
scottysimp7's Avatar
scottysimp7 scottysimp7 is offline
The motor is here!!! She is just beggin to be run hard.
421 stroker
bowtie block
scat rotating assem.
dart heads
edelbrock intake
canton road race pan 8qt
tuned 950 quickfuel carb.
This beast made 561tq @ 5200rpm and 591hp @ 6100! BRING IT!!!!!
68 Camaro
DSE sub
Quadralink Rear
Ford 9inch
Baer Brakes
Skip White Racing 421sbc
Tremec TKO600
Old 03-24-2011, 11:25 PM
Flash68's Avatar
Flash68 Flash68 is offline
Scott, that looks bad ass man. Bet you can't wait to hear it fire up!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 03-27-2011, 07:42 AM
DETON8R's Avatar
DETON8R DETON8R is offline
Default Nice, Very Nice!!
Scott, looks like your project is coming along pretty good. It is good to hear about more pro touring car builds here in Santa Cruz County. We have some of the best mountin roads around for a PT car, even though they are pretty messed up at the moment. That bad small block shoud disturb the peace up here in the mountains pretty good. Looks like you will have your car on the road long before I get my 69 on the road with the progress you are making!!
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 03-31-2011, 02:04 AM
I agree. We do have some great twisties.
68 Camaro
DSE sub
Quadralink Rear
Ford 9inch
Baer Brakes
Tremec TKO600
Old 04-05-2011, 04:00 PM
Mrfixit Mrfixit is offline
Arrow
Originally Posted by scottysimp7 View Post
I need help on wheel fitment. I am considering doing a staggared set up on my car. 18in front 19in rear. 275front and 325 rear.
Any thoughts or guidence?
I just got my new Billet Spec 18" wheels mounted on my project car. The rears are 18x10 6.5" BS w/ 295/35/18 and the fronts are 18x7 4.5" BS w/ 225/45/18.
Rear: fit is great. No issues with clearance and with a 1" gap between the top of the tire and radius the fender it leaves a full 3" of clearance from the top of the tire to the first contact of the wheel well. The bulge of the tire is measures 2.25" to the outside edge of the fender lip (used to gauge the looks, not clearance). This may not be of much use to you because, while I'm using the DSE Quadra Link and mini tubs, I'm using a 9" from a 68 Bronco so the track width is a little different.
Front: Fit is OK. If I had it to do over I'd go with a 4.75 or even a 4.875". I can't give any final measurements until the car is finished and aligned but for reference, the tire bulge is 1.5" from the outside of the fender lip. I'm using the stock subframe with the Gouldstrad conversion and off-brand (read cheap) tubular upper and lower control arms. I'm planning on changing to the 1/2" taller upper ball joints with the hope that the better camber curve help keep the tires from rubbing. Additionally, I've installed the 13" rotors and PBR 'Vette calipers. The tire vale is only 1/2" away from the caliper. The only way to make a 14" rotor and the PBR caliper clear an 18" Billet Spec Dagger wheel would be to move the tire stem location either to the outer lip or to the inner lip.
I hope this helps a little.
Old 04-13-2011, 05:39 PM
Still making progress!
68 Camaro
DSE sub
Quadralink Rear
Ford 9inch
Baer Brakes
Tremec TKO600
Old 04-13-2011, 05:53 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very nice Scotty.
Old 04-13-2011, 10:06 PM
Flash68's Avatar
Was just down there last Friday.... sh!t is lookin good Scotty!
2014 4 tap Keezer
Old 04-14-2011, 10:18 AM
awr68's Avatar
awr68 awr68 is offline
Progress is a great thing! Did you decide on wheels/tires yet?
Tony
'68 Camaro
Old 04-14-2011, 11:42 AM
I just ordered tires and wheels. Jon at DriverzInc set me up with Forgeline GA3R's silver w/polished lip. Running on Falken Azenis615's. Cant wait!
68 Camaro
DSE sub
Quadralink Rear
Ford 9inch
Baer Brakes
Tremec TKO600
