Here is the start and the basic layout of the chassis center section. I ended up going with 1-3/4" 14 gauge (.083) mild steel for the bulk of the chassis. The cage will probably be 1-3/4" x .090 DOM
I have a blueprint from a GT chassis and that is what they used so figure I should be safe as long as it is properly built and triangulated and such.
Waiting on a couple of Ebay axles so I can make sure I am OK on the track width before getting too far into the rear clip...which is next up.
I talked to a shop in Florida that said they can modify the 5 bolt output flanges to fit the 6 bolt 350z hubs. I ordered a Q45 and a 350Z left axle so I can kinda double check lengths and all are compatible.
Started making a fixture for the Q45 diff so I can get it set in place.
rear view
[/IMG]
front view
[/IMG]
