Old 07-09-2011, 06:33 PM
Very inspirational Mike. I will eventually have to do something about the console in my TA. This gives me some ideas. Keep up the good work.
Old 03-13-2012, 06:27 PM
scherp69's Avatar
scherp69 scherp69 is offline
Thanks for the comments guys.
So I've had a few questions about building the console. Here's a response that I put in another thread and thought I would add it here in case more people are wondering what I've done.
As for the building of the console, it's actually very simple and no high cost tools needed. The biggest thing about building a console like this is time. It will take alot longer than building one out of mdf, but the nice thing is it's a custom piece that fits exactly how you want it to. It's all trial and error. Measure, cut, tack, test fit, fix, text fit and carry on :devil:
One of the tools is a ring roller, or a roll bender. Mine is a Magnum brand which I picked up from KMS Tools, a tool store that has a few locations throughout the province. I think I paid about $75 for it on sale. Here's the one that I have, it's very similar to the Baileigh one, I just didn't have to pay for the Baileigh name. I'm sure mine isn't as good as the Baileigh one though.
What this tools does is allow you to roll round bar or flat stock. You can roll it to a complete circle or just make a piece curved. I used this tool to do the pieces that fit over the trans hump in these pics
This allowed me to build the console so it would fit nicely on the hump. I thought about just using large barrel or tank to help shape the round bar, but for anyone that's seen my build knows..I like to buy tools so I decided I'd rather have the tools. I plan on using round bar in a few more areas of my build.
The second tool I've used is this.
They just call it a universal metal bender and I think I paid $40 on a sale. You can change the dies and it allows you to make circles in the metal. I paid $10 extra to get a DVD that shows what the tool does. Looks like guys use these to make round bar art when there are lots of bends. I used mine to make the piece around the parking brake in this pic. I'm also going to use it to build some pieces to hold up the cup holders.
Those are the only two specialty tools that I've used for the console. The other tools I've used are: a hack saw, hammer, vice, measuring tape, welding magnets and of course a welder.
The round bar that I'm using is 1/4". I got all mine at Princess Auto....it's kind of like a tool junk store that has several stores throughout Canada. Not sure what store would be similar in the US. You can also get round bar at Home Depot and most places like that. You would also be able to get it at most steel supply stores, I just prefer to get mine as I need it. I usually pay $5.49 for a 5 foot piece. I think Home Depot charges $4.99 for a 3 foot piece.
When you start your console, measure the area that want it to fit into and start cutting. If you want to use a piece of cardboard to make a template, that might make it easier to get the design that you want. I just use the trial and error method and changed it as I went. Make sure that you allow for clearance of carpet, underlay and any sound deadner that you might use. When I started to do mine, I forgot to do this and had to cut it down to allow for it. Use the welding magnets to hold pieces in place and tack weld them. I eye balled all my bends and angles until they looked good. Now that I'm doing a lid for mine, I may have to make a few adjustments to make up for the "eye balling".
As for the 90 degree bends, I used a vice and a hammer. Mark where you want the bend to go and put it in the vice. You may want to try a couple practice bends to see where it bends in respect to where you mark it. I start by bending it by hand as the 1/4" stuff bends quite easily by and. The problem with bending a 90 degree by hand is that the bend ends up quite rounded. Once I have it done by hand, I use a heavy ball peen hammer while it's still in the vice and hammer it down to get a nice tight bend. These bends were done by hand and then with a hammer.
Alot of the 90 degree bends are welded. This piece of the console has quite a few bends and they were all welded into place. You can see how this piece has quite a few odd bends and angles on it. This is because I wanted to make it fit just right. I had to make alot of the bends and angles to fit around the Vintage Air unit that's shown in the second picture
Like I said in the beginning, the biggest factor in building a console like this is time. I don't even know how many hours I've spent building this one. It adds up though once you tack things into place, fit, weld, clean the welds and test fit again and make any changes that you need to. Once mine is done, I plan on wrapping it with 20 gauge sheet metal and then with leather. The main reason I chose round bar was it allowed me to make a real custom piece that fit exactly how I wanted it to. It was also alot easier to make changes as I could just cut out the area I don't want and weld in a new piece. Not as easy to make changes with mdf or wood and still keep it strong.
With the questions I've been getting lately and seeing other guys make consoles with round bar, it got me motivated to do some more on mine. Here's what I've gotten done over the past few days:
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 03-13-2012, 06:28 PM
scherp69's Avatar
Looks like Mickey Mouse
You may have noticed that I'm using different cup holders now. I ended up getting some smaller ones from a poker supply store. They are the same ones that they use in the Vegas poker tables. Thanks again for the idea Rene. Here's what they look like. I paid $30 shipped for all 4.
Much nicer than the ones I originally had
Mike
New Gen Splitters
LS3 and TKO600
Old 03-16-2012, 07:52 AM
Depthrecordings Depthrecordings is offline
Dude,
This is awesome. I plan on doing something similar in my 67. Thanks for sharing on what tools you are using to do this. I cant wait to see what it looks like when it's all finished up. Keep up the good work!
Eric Bernal
Denver, CO
67 Project Camaro
Link to my build:http://www.camaros.net/forums/showthread.php?t=202010
Old 03-16-2012, 04:06 PM
scherp69's Avatar
Thanks Eric. Hope the info here helps with yours.
Made some more progress on the console the past couple days. I actually think this is the coolest part of the console.
Picked up a shift boot and billet boot ring. I went with the Lokar kit part # 70-BFMB. This thing is sweet.
Since the ring is so thick, I wanted to try and sink it into the console a bit. I started with some 1/8" flat stock and cut it to the size I wanted
Welded it together
Drilled and tapped the holes into the flat stock
Added some round bar. The way I added this, I left enough room around the ring to fit the leather (if I still go with leather)
Today I added it to the rest of the console
Tested some bottles of water in the console. It is tight, but I can adjust the shifter some to help give me some extra clearance
Next week I'm going to start working on the storage area lid. I've tried using round bar, but have been fighting with all attempts. Once I used the flat stock, I realized that it will make a good base for the lid. I'm going to drill and tap holes for the hinge bolts. I have two parts done, one piece will go on top of the console and the other will be the base for the lid.
Mike
New Gen Splitters
LS3 and TKO600
Old 03-16-2012, 04:17 PM
scherp69's Avatar
I've decided to add a poll to help me decide how to finish the console. If you want to vote, here's the link: https://lateral-g.net/forums/showthread.php4?t=36070
Mike
New Gen Splitters
LS3 and TKO600
