View Poll Results: TKO600 - keep it or sell it
Keep the TKO600 3 30.00%
Sell it and get a RS600 1 10.00%
Sell it and get a T56 5 50.00%
Other options 1 10.00%
Voters: 10. You may not vote on this poll
Old 04-12-2011, 06:20 PM
The WidowMaker's Avatar
the numbers are posted somewhere, but the shifter is a little over an inch back. it wasnt too bad. if you only have 1/4" clearance around the outside its going to be too tight.
you can also get all the parts from liberty for MUCH cheaper. theres a thread somewhere that lists all the prices. i was told that if you have ever built a motor that you could put in the parts that are needed to make it shift better.
"The WidowMaker"
