Old 06-29-2011, 10:38 AM
68KMARO 68KMARO is offline
Default console
Great work and thanks for all the pictures.
rich
Old 06-29-2011, 10:54 AM
cencalc6 cencalc6 is offline
Very Nice
Old 07-26-2011, 04:46 PM
sweetstang68347's Avatar
sweetstang68347 sweetstang68347 is offline
So nice...
Old 08-12-2011, 01:13 PM
DarkoNova DarkoNova is offline
Banned
WOW that's a nice console. I was kinda disappointed when I measured between my seats and found out a 98-02 Fbody console won't fit, but after seeing this, I'm definitely gonna try to make my own console.
Old 09-07-2011, 08:13 AM
chuckd71 chuckd71 is offline
How did you get the mdf to curve outward as it goes from the rear toward the front? That looks similar to what I was going to try.
Old 09-07-2011, 10:50 AM
70rs's Avatar
70rs 70rs is offline
You can make compound curves, radiused panels and things like that a number of ways. One is to use 3/8" "bender board" and laminate (glue) two sheets together in the shape you want over a wood buck or jig. Or you can use 1/4" MDF sheets and do the same thing. Make your parts oversized and cut/sand to your final shape.
The console in the video looks very nice, and I imagine there is a lot of time involved. But the basic outside shape is fairly straight forward to make and you should be able to duplicate it yourself.
Post up pictures of what you make.
Eric
Old 09-08-2011, 12:50 AM
I don't have a whole lot of tools, hell I don't even have a table saw so version 1 might have to be at least mostly flat on the sides. The thing about sticking sheets together and then cutting from them what I want is what I had planned on doing if I had tools, but I think I might make it straight and maybe just add some bondo on the sides to fill it out before covering it. I'll mount a couple gauges, ridepro e3 controller and a cd player in it, but there is zero chance it will be anywhere near as nice as the one in this thread. Looks like he used some plexi for the part holding the screen?
The gauge holder in the second pic here is the result of my first experiment with fiberglass. Functional, but ugly.
http://ls1tech.com/forums/14937962-post182.html
Old 09-08-2011, 04:03 AM
Scorpner Scorpner is offline
You could always carve the shape you want out of foam and cover it in fiberglass to finalize the shape. Depending on how much you'd need to use, bondo may be too heavy. For the pic on the other site I might try making a block of foam and then marking and carving what you want out of that. It will get messy though. (I might even angle the face towards the driver somewhat.) This site may help as well. >Link
That being said, it(the console here) looks to me that the wood on the sides is thin enough to follow the curves. (Otherwise, plywood can be soaked and molded to a form.)
Another thing you can to to get a feel for how the flat panels can bend is to use cardboard and tape. Then use the cardboard as a template for the MDF or whatever you decide to use.
I also don't see where a table saw would be necessary. A simple jig saw with a straight edge and clamps can get you by for the straight edges. I built a lot of things like that when I didn't have access to a table saw as a teen.
'85 F-41
'86 Camaro
Old 09-08-2011, 10:03 AM
70rs's Avatar
Jig saw, small/inexpensive sander from harbor frieght, spray adhesive, bondo or sheet foam(blue insulation from home depot) cut that with a steak knife....cover with fabric or vinyl or leather.....one custom console for under $100.00 including the sander and jig saw from HF. Dont use the foam for structural parts. Too soft. Just use it to contour the shape you want. Adhere it to the wood base. Use 3M spray90 adhesive. It stinks but it works way better than the spray77 version.
With a little practice you will be amazed at what you can make.
Eric
Old 09-15-2011, 09:19 PM
If you told me that was from a newer car I would believe it. Beautiful job.
