Old 05-30-2011, 02:40 PM
Flash68's Avatar
Flash68 Flash68 is offline
Default Camber: does this look right? (track video inside)
...videos from Willow Springs track day 2 weeks ago.
kep points:
-2.2* camber -- alignment done right before track day
Global West control arms
ATS AFX spindles
need further info?
We were surprised to not see more dynamic camber in this video. Any ideas?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-30-2011, 04:23 PM
chicane's Avatar
chicane chicane is offline
Kinda hard to actually tell... from the vantage of the camera.
Just sitting still from that vantage... doesnt even show the static that you have dialed into it. But in motion... it does look as if the tire had enough camber in it to address body roll and the suspension compression.
You dont have any tire temps do ya ?
Old 05-30-2011, 04:31 PM
Track Junky's Avatar
Hard to tell, it looked square in the well..............the best way to measure would be with tire temps across the face of the tire......and on that note the worst way to find out is when your tire is bald on one side, lol.
Gaetano Cosentino
Old 05-30-2011, 04:37 PM
Flash68's Avatar
Yes tire temps were recorded throughout the day but that folder is in the car and I am not with said car. Will have them later tonight and will report back.
Thanks guys.
2014 4 tap Keezer
Old 05-31-2011, 07:39 PM
Flash68's Avatar
Ok got temps for you guys. CCW track.
1st session -- warmup
Left Front: Outside to Inside = 88* to 89*
Right Front: Outside to Inside = 100* to 100*
Left Rear: Outside to Inside = 87* to 89*
Right Rear: Outside to Inside = 114* to 110* to *103
2nd session -- litte faster
Left Front: Outside to Center to Inside = 100* to 107* to 108*
Right Front: Outside to Center to Inside = 117* to 116* to 113*
Left Rear: Outside to Inside = 105* to 109*
Right Rear: Outside to Inside = 108* to 106*
3rd or 4th session -- full boogie
Left Front: Outside to Inside = 100* to 106*
Right Front: Outside to Inside = 132* to 127*
Left Rear: Outside to Inside = 106* to 106*
Right Rear: Outside to Inside = 122* to 117*
Over the sessions we also gradually brought tire pressures down from 35 to 32 psi cold, and they were gaining about 5 psi per session.
Comments?
2014 4 tap Keezer
Old 05-31-2011, 08:20 PM
Hmmm.......first thing first, are you experiencing any under steer? If not, a little more neg. camber might help. When I ran 255/40's up front I ran -2.5 camber. Where are you at now?
Gaetano Cosentino
Old 05-31-2011, 09:17 PM
I thought that was before the sway bar..
Old 05-31-2011, 09:19 PM
Flash68's Avatar
Nope. I've had the sway bar for every autoX and road course I've done.
I never thought the understeer was as bad as Mary thought, but what do I know? I have no baseline.
2014 4 tap Keezer
Old 05-31-2011, 09:29 PM
315's in the rear with 245's up front doesn't help but I know 275's in the rear are not an option for you.
What front and rear spring rates are you running? Adjustable shocks?
Gaetano Cosentino
Old 05-31-2011, 09:33 PM
chicane's Avatar
Dave - Length of time before temps were taken ??... in the future, try and get inner, center and outer temps... as it will associate to any pressure issues that may be present or help explain possible cupping issues.
The second, third or fourth run temps do show an alignment issue... and my intripretation is that you need to get the chassis scaled to verify my input. I believe that you need to read your corner weights, with you in the car, just after you do the alignment with you in the car. Basically, set the car up as you would be on the track... do an alignment and then scale it... with you and the amount of fuel (perferrably totally full or totally empty.)
Another question... which direction were you running the track and which course was set up for that day ?
The only thing that stands out to me... is the RR temps. The chassis either needs more cross weight to distribute the front loads better and to take some load off of the right rear. Its either that... or a possible bend housing or a loose differential... ie, worn clutch packs or not enough preload shim to the clutch pack.
If I could see scale numbers, as it is... before any change, that would help.
But seriously, nothing to be really alarmed with. They -look- proper... and it just needs a little nudge in adjustment.
