Old 06-03-2011, 03:35 PM
This all jogged my memory. Energy mounts are about an 1/8 taller than a factory rubber mount.(That's 1/4" total) 302/350 rubber factory mounts are interlocking as well. Solid mounts have there pluses and minuses.
Old 06-21-2011, 11:48 AM
70rs's Avatar
70rs 70rs is offline
So is that bad boy installed yet?
Eric
Old 06-22-2011, 04:48 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
X2....update??
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-26-2011, 09:48 AM
NvrDun71 NvrDun71 is offline
Originally Posted by 509Chevelle View Post
X2....update??
x3
71' Nova - LY6, T56
Old 07-21-2011, 11:17 AM
What ever became of this?
71' Nova - LY6, T56
Old 01-30-2012, 05:03 PM
What ever became of this ordeal? lol. I have a set of energy suspension mounts with S&P plates and wondering if I will be having the same problem? Any info is appreciated as I am on the fence about the backing plate as well.
71' Nova - LY6, T56
Old 04-04-2012, 08:41 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
Did you ever get this resolved . I'm interested also. I also have the poly mounts on a 454 in a 67 camaro and cant get them down over the mounts, the engine fit perfect with solid mounts and I wanted to calm it down a little bit.
Old 04-16-2012, 10:50 AM
64pontiac 64pontiac is offline
You may have this figured out already, but I figured I could chime in.
You do not use the preload plates when running an LS adapter plate. The adapter plate becomes the preload plate. When we machine our own adapters we put a pocket in for the "bulge" of poly just like the stamped metal preload plate. The metal preload plate is used when you put the mount on a chevy SB or BB, just as has been posted.
Also, I will point out that on ATS mounts, Art Morrison Mounts, and our own mounts the energy mount pad is actually "upside down" in relation to how you normally view the mount. This helps lower the motor.
Make sure your stands that bolt to the frame are for a Chevy too, if one is taller from the bolt hole center to the top surface it won't help your situation
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
