Old 08-01-2011, 09:36 PM
g356gear's Avatar
g356gear g356gear is offline
Default COMP cam magnum rocker nut failure
So I took the car out for a little spin today. I had installed Magnum roller rockers , guide plates and pushrods about 100 miles ago. I have a medium lift hydraulic cam in the motor....nothing too radical. I left from a light with a little of go petal and the car popped a couple of times and I backed out right away. The car immediately felt like it was down a cylinder. I pulled over and checked for anything odd. There were not any strange noises at idle and oil pressure was still good. I went straight home and could tell something was off in the motor. If I brought up the RPM's, I would get a little rattling out of the drivers side front of the motor. I let it cool down and pulled the plugs to check for anything nasty. #1 plug was black and wet, others all light tan and dry. I pulled the valve cover and found the pics below.
Has anyone seen this from COMP products before? Any ideas on a better product that's not going to do this on another pushrod? Needless to say the metal is nowhere to be seen in the cylinder head. I am hoping it's in the pan. I have a magnetic plug so my fingers are crossed.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
