Old 02-02-2017, 07:19 PM
ArisESQ ArisESQ is offline
Love this build - it's looks great now, and it'll look even meaner once you have the rideheight and alignment dialed
What size tire are you planning on running? Sticking with those wheels?
Awesome car, man!
Old 02-03-2017, 06:05 AM
nicks67ca nicks67ca is offline
For now i'm sticking with those wheels. They are corvette 18" replica's which are pretty cheap. I need to recover some from the other major upgrades I'm doing. Eventually i'll probably move to the Forgestar wheels. I'm running a 265 front tire now. I'll probably keep the 265 size or move to the 275.
Old 03-02-2017, 11:12 AM
Getting some painted parts back! Need to get time to finish the firewall and subframe connectors
Old 03-27-2017, 05:01 AM
Firewall fill plate just about in. Need to finish some bottom a little but its just about done.
Tack
ground down
up next Sub frame connectors and Engine mock up and frame down bar installation!
Old 03-31-2017, 11:15 AM
I also test fitted the Holley mid length ls swap header. 1 7/8" primary with 3" collector. Need to verify in the car with mast pan and speedtech mounts, and steering shaft.
Old 04-01-2017, 02:07 PM
Mikael A Mikael A is offline
Very cool...how do you like that frame,was considering getting one.
Mike a
Old 04-01-2017, 07:23 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Car is coming along and looking good!! Keep at it.
Curtis
Old 06-05-2017, 06:02 AM
Got some stuff done.
DSE subframe connectors are in
Down bars are in. I decided to weld them in with a removable tube adapter and the plates welded to the firewall. I have some clean up to do still. Next is to finish the trans tunnel with the speedtech cover then power wash / steam the underside and get the whole thing ready for undercoating and firewall paint.
Old 06-05-2017, 02:00 PM
looks great
Mike a
Old 06-05-2017, 03:46 PM
Spiffav8's Avatar
Lateral-g Moderator
Nice! Yeah that doesn't suck!
Curtis
