Gotta catch this thread up! I've been working out the suspension design in CAD. I was originally going to have the lower control arms brackets laser cut, but needed them faster than the local company could get them to me (plus, they would have taken a nice little chunk out of the project budget for such a low quantity). The little notches are position markers, that indicate where the bracket is located on the frame rails (positions 1 through 8 from front to rear, mirror image side-to-side).
So, we decided to hand cut them. We cut poster board patterns on our small laser (it won't cut steel or thick metals), and the process is underway now to make the sixteen brackets. We have the 16 suspension pivot holes measured, marked, and drilled, so far. Tomorrow, we will start cutting the other critical apsect - the right angle corners that actually mount on the frame - and then the outside profiles.
Later, I will box the tops of the mounts in with hammered steel pieces, like this. The bottom will get a normal boxing plate.
I'm also working on component layout, in Rhino. I did the suspension bracket design in Rhino as well, because they're just flat plates, with a couple critical dimensions. I will be doing some, more common, solid modeling in Pro/E soon too.
Please excuse the crude shapes - accuracy in modeling them wasn't important, where everything goes is. The stacked dark grey objects under the front diff and motor, and in the floor, are the battery modules. That theoretical pack has 333 volts/1800 amps = 800hp potential, but it wouldn't all be used. The controller I'm thinking about for this project (grey box over motor and diff) is rated for 1000amp max (also continuous power rating) and about 400hp. I'm actually only looking for 200-300hp at the front wheels. The excess in battery, controller and motor capability, is for reliability; and, in the case of electric propulsion, also means more range. It should have the typical hybrid type "all electric" range of 30-40 miles from that little battery pack, because it's small and lightweight. I don't care about that so much, because I can drive until gas stations won't sell me any more fuel.
The yellow boxes are the fuel tanks; about 7 gallons worth - good for 300-ish miles, enough for the solid mounted everything, and cramped quarters, to say get out for a while, anyway.
The chassis design was inspired by the old school underslung hot rods, where (as I understand it) they flipped the frame 180*, hanging it from the axles to get the car lower. In this modern, independent suspension, kit car, version the point was the flat frame. It allows us to easily mount a variety of drivetrains, and hang a lot of componentry on the frame rails, as low as possible. It pushes the engine and transmission up higher than it would normally be, but I am hoping that everything else being mounted so low will counter that. We'll see...
