Old 03-29-2012, 06:57 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Default Dry sump tank in trunk?
High Guy's, I am thinking of putting my dry sump tank in the trunk of my 69.
I am looking fo the pro's and con's
Greg
Old 03-29-2012, 07:43 PM
Rhino Rhino is offline
I've not done it in a car but I've had the tank behind the cab of a truck. The additional oil volume can help keep temps down if needed.
On the downside, it could prove to be the source of a mess during oil changes or you run into issues.
Old 03-29-2012, 07:59 PM
Thanks, Is there any pressure loss from the longer piping?
It would penetrate the trunk floor so, an oil change wouldn't be a problem.
Greg
Old 03-29-2012, 08:12 PM
We didn't witness any, but you need to insure your hose is sized appropriately.
The oil pressure is created by one (or more) of your oil pump stages. The rest pull a vacuum on the motor and return the oil to the tank. All that being said, the tank itself isn't under much pressure.
Edit: Full disclosure, this was in a 4x4 modified pulling truck, not a street car, so I can't answer to how corners may effect this setup.
Old 03-29-2012, 09:35 PM
Motorcitydak Motorcitydak is offline
The line(s) going from the bottom of the tank to the oil pump will be under suction. Make sure that the hose you use for that cannot be collapsed. I would not suggest using a regular rubber hose for that. Maybe braided or something similar
Old 03-29-2012, 09:45 PM
chr2002ca's Avatar
The Corvette Racing team puts their sump tanks in the back of their cars so it seems like something that has more pro's than con's if you do it right. I placed my 3qt Accusump in the back of my ride and noticed very little pressure drop. Not quite the same of course, but some of the same principles.
Chris Robinson
