Old 04-27-2012, 09:13 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Originally Posted by Matt.A View Post
I had Inland Empire build my drive shaft. It took them two tries and they still didn't get it right so I had a North County San Diego shop (Oceanside Driveline) fix it due to time constraints. I seem to recall this happening to Rupp once and they fixed it on their dollar, no hassles or anything. If I was local to them I wouldn't hesitate to have them build another drive shaft for me in the future. I want to think I just had bad luck.
Matt
What was the issue Matt? Just wondering? Length? Balance? Yoke?
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 04-27-2012, 05:03 PM
badmatt's Avatar
badmatt badmatt is offline
Originally Posted by killer67 View Post
How much is that going to run?
right around 950. Mainly for saftey... because I do not see the driveshaft exiting from under the vehicle at a 3.5" ride height... "just in case" there is also a loop.
Now see the problem I have with aluminum shafts is when you weld 6061 if I remember correctly the joint and HAZ area is weakened by 61% or so.. IF remember correctly don't quote me if Im wrong.
Matt
Old 04-28-2012, 09:31 PM
The WidowMaker's Avatar
started with dennys and they will shorten for free, but with shipping both ways and their materials charge it was still running me over $100. great guys and if i was closer i wouldnt hesitate.
socal though is a different story. after needing work done i took it to http://www.drivelinesinc.com/. i havent run it, but nice guy, great work and he does stuff for robby gordon and others.
"The WidowMaker"
