Closed Thread
Old 05-15-2012, 07:54 AM
505camaro69 505camaro69 is offline
Default Ring Brothers Hood Hinges question
The hood will not stay up, the struts are the 260# versions. I have a stock Cowl induction hood. They were installed by Prodigy Customs when the car was painted and assembled last summer.
Do I have defective gas struts or do I need different struts?
Has anyone else had this problem?
Does anyone know what strength of struts are used by the other billet hinge companies?
Thanks for your help.
Old 05-15-2012, 08:03 AM
kttrucks's Avatar
kttrucks kttrucks is offline
The hinges come with specific struts based on your hood... IE- steel, fiberglass, etc... Talk to The Rings and you should be able to tell by the part # or some visual cue on the strut itself. I remember Staci asking me specifically what hood I had, and the struts were selectedbased on my answer. It could be that your builder mistakenly installed the wrong ones? ( dont take that as a slam on your builder.... not my intention, but mistakes do happen and that would be an easy solution to your problem.)
KT.
PTFB, Viking, Holley Performance Products, BFGoodrich, Heatshield Products, Turbonetics, Hellion Turbo Systems,TCI, Dennys driveshafts, Eastwood, Preferredline Media, Summit Racing, Strange Engineering, Forgeline, TMI Products, DBR High Performance, Spectre Performance, Vintage Air, NPD, Digitails, Redline Lumtronix, Dakota Digital, Newport Engineering, Stage 8 fasteners, Industrial Depot, Brian Finch, Grant Salter, and many more Good friends with big hearts.
Old 05-15-2012, 08:06 AM
ironworks's Avatar
KT.
Also those gas struts work differently in different temperatures and the weight of the hood can change considerably after paint. What works in the winter on a baremetal project will change in the summer when it's all painted.
Just my experience.
Old 05-15-2012, 08:07 AM
I have the Ring Bros hinges with a steel hood and I've never had a problem in 3 years. Call them....
Old 05-15-2012, 11:17 AM
That was what I was expecting.
I did call Ring Bros and they told me that the 260# struts work on greater than 90% of first gen cowl induction steel hoods (not 100%) and that I could purchase the 325# struts for $67.50.
Am I expecting too much? At over $600 I thought that I wouldn't have to worry about them working at least as well as the stock hinges.
I still have a lot of other parts needed that I could put that $67.50 towards.
Old 05-15-2012, 11:23 AM
jy211's Avatar
jy211 jy211 is offline
buy the #325 and then sell the #260 to re coup some cost
Old 05-15-2012, 11:28 AM
ironworks's Avatar
If that is the only extra part you have to buy in your entire build, Your doing way better then me.
If you have not figured it out yet, no 2 cars are ever the exact same. Just buy the #25's and put up your other struts up for sale to the guy who made a hood change or did some other swap. Lots of people have to do that.
If Ring Bros sold you the 325 and it held the back of your hood up from being to stiff you would be on here complaining that you hood was lighter then expected.
I could never find a gas shock light enough to hold the back of my carbon non-cowl hood down properly so I have to just not run a strut or have some rear vent from the hood peaking up if I do. Lots of guys run a carbon hood with no problem, Not me.
Old 05-15-2012, 12:54 PM
I hope I'm interpreting your post wrong. My point is, they work just fine with the correct/functioning struts. My bet is on the wrong struts.
Old 05-15-2012, 05:15 PM
It's a hot rod ---- and if you can afford $600 hood hinges -- you can afford a lousy $67.50
You bought 'em from Frank. Did he install 'em? Did you spec the 260# strut? Why should the seller be responsible for someone else's mistake?
Old 05-17-2012, 09:19 AM
Ringbrothers Ringbrothers is offline
I also told you that we have a one year warranty policy and if you could provide me with the original invoice I would be happy to replace the gas struts for you at no charge. If it has been over a year then you would need to purchase the struts. Gas struts are not an exact science. Everyone's hood is different.
I'd be happy to except the invoice from Prodigy... if it has been within the 12 month timeframe.
If you have any further questions please email me at [email protected]
Closed Thread
