Old 07-22-2012, 05:57 PM
Flash68's Avatar
Flash68 Flash68 is offline
Spend 11 Grand and buy yourself a real motor....
http://www.smedingperformance.com/ch...orsepower.html
Originally Posted by makoshark View Post
That's a smoking price for a small block 427. Look at what you get, all forged motor, Dart block, carb to oil pan with 3 year warranty. I can guarantee that you cannot build that motor yourself for that price, with warranty and already dyno'd and tuned. Absolutely nothing wrong with sticking to the old school small blocks. I have nearly that much in my 350 and its not dyno tuned, nor does it have a warranty.
Heck you can get 540 hp out of a hydraulic roller 383 with good quality parts for a lot less.
I'd say keep the block if it's good, stroke it and put some good heads on there and you'll be happy with over 500hp.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-22-2012, 08:23 PM
Bucketlist2012's Avatar
Bucketlist2012 Bucketlist2012 is offline
Thanks.. I will look into that..
That is why I am asking, so I get opinions. I won't pull the trigger until around Christmas.
I will go in for a "tune up"...
Luck is the meeting of preparation and opportunity
Pro Touring 71 Z/28 in training
Soon to be crazy
Old 07-22-2012, 09:04 PM
intocarss's Avatar
I do like the idea of big Cubic Inches. But I agree with Flash. My buddy built Mike Wrights (Black 69 PT Camaro) 383 and it makes 541 Hp and 519 tq
It's JMOHO but you have a 70's OEM LT1(From carb to pan) Why gut it just so you can use the block. It's got to be worth some $$ as a whole? If you're going with a OEM block , you can find those pretty cheap. Then get your rotating assembly, cam, heads etc and you're ready to go. I myself prefer an after market block for anything over 500Hp
Old 07-22-2012, 09:10 PM
Flash68's Avatar
Good call, Jer.... Mike's 383 is a perfect example.
2014 4 tap Keezer
Old 07-22-2012, 09:38 PM
Thanks for the Info..
I was always about it being a Real Z/28 with the real driveline, but I have gone crazy on the suspension and brakes, so it may not matter anymore..
I may just want to set the whole engine aside In case I ever sell it, and replace the engine and M-21 with something new.
I agree with not gutting it because it is original from Carb to pan. except for the comp cam valvetrain..And it is .40 over
What about local engine builder's ? I still am going to ask Steve about it, but I wanted to get opinions before I talk to him..
My timeline is Around the holidays and the new year..So plenty of time to think and also beat the snot out of the set up I have now.
I will autocross this set up in November in Pleasanton before doing anything..
Soon to be crazy
Old 07-23-2012, 06:55 AM
clill's Avatar
clill clill is offline
I agree with saving the orig. #'s matching engine. If you look around you can probably find a great deal on a built up smallblock that someone has taken out because they are putting a LS in. That leads me to my next suggestion which is to bite the bullet and switch over to a LS engine. They are just lightyears ahead of what you are wanting to throw money at.
And didn't someone just recently post problems with a Smeding engine they had just bought ?
Old 07-23-2012, 07:36 AM
I just threw a ton of money on parts for my Small block...Ceramic coated headers, aluminum water pump, fuel tank, ect... They are brand new.
If I knew my LT-1 was feeling tired, I wouldn't have thrown all the money at it, and I would have waited to go LS.
I may just have to increase the power on what I have and live with it for a while.
Soon to be crazy
Old 07-23-2012, 07:38 AM
I've never heard of an engine builder that "someone" hasn't had a problem with... Usually it's never the actual person that BOUGHT something - but they had a "friend" or someone they knew that did...
Old 07-23-2012, 07:45 AM
It isn't like my car doesn't run, and it is a mid 13 to low second car.
So I may just wait until the end of the Year to see where the Election and the tax cuts go..
I mean I can still drive my car, and Cash is good to have for now...
Soon to be crazy
Old 07-23-2012, 08:36 AM
hotrod69camaro's Avatar
hotrod69camaro hotrod69camaro is offline
I put together a 383 hydraulic roller pump gas sbc for my 69 and it was between 10 and 11k. Made 541 HP on the dyno. And thats starting with everything new.
