Old 08-27-2012, 02:29 PM
68SS2 68SS2 is offline
Originally Posted by HEEP View Post
Here is a link.
http://www.ohiopowertool.com/P-666-n...FYg7MgodJhsA5A
It is well worth every penny I paid for it. It will reach a HEEP that is lifted 4" running 35" tires by the rocker panels. Lift height is 32"
Problem I see at this point, I do not see it on the NORCO web site. Might want to buy if you can at the link supplied.
HEEP
In the link and through other sites, I have found this type of Norco jack, but it looks like the models are either 32" lift height with 1.5 ton capacity or lower lift height with 3 ton capacity. Which model is the one you recommend? I would actually want a bigger range with a higher capacity.
Old 09-02-2012, 04:19 PM
transam's Avatar
transam transam is offline
I use an ac hydraulic for day to day use, by far the best jack i have used, rubber o rings on the wheels for silent rolling. I use a Cheap offshore generic tool store jack when i need to get a car several feet off the ground or loft my dually up.
Old 09-06-2012, 08:28 AM
HEEP's Avatar
HEEP HEEP is offline
I ended up with the 1.5T with the higher lift. I was after the height. I have a standard 2T that handles other lifting duties.
Amazingly, the 2T was bought at Sears 28 years ago and is the best jack in the world. It has never leaked. Crap, did I say that out loud? Better check it when I get home.
HEEP
Old 10-22-2012, 08:20 PM
RdHuggr68 RdHuggr68 is offline
Alcans 3.50 ton jack is now rated at 3.25 ton due to new safety specifications for 3.50 ton jacks. Alcan said the jack did not meet the new specifications required to be rated at 3.50 tons so they now call it the 3.25 ton. Just bought one at Costco $99.00
model #XL325R
Old 10-22-2012, 09:06 PM
Flash68's Avatar
Flash68 Flash68 is offline
I'm gonna pick one of these up I think. Just called and most bay area stores are carrying it.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
