Old 08-23-2012, 05:07 PM
Sieg's Avatar
Sieg Sieg is offline
Default Holley HP Series Carbs
I'm in the market for a new carb for my 355 Gen 1 motor after the engine fire. There are a number of configurations of the HP, I like the features of this new HP Ultra: http://www.speedwaymotors.com/Holley...CFM,55779.html Sight glass, larger bowls w/ drain plugs, billet baseplate, etc.
The question is 650 or 750? I'm leaning 750 since the motor didn't feel over-carbed with the previous 650 Speed Demon and my goal is a larger displacement 370-380 Gen 1 motor.
The hydraulic cam is unkown but rather aggressive 10.5-11" at 950-1K idle, estimate the compression at 10-10.5, will have AFR 190 heads with Edelbrock Performer RPM Air Gap manifold, I also need to replace the ignition - I'm leaning toward this MSD kit:http://www.summitracing.com/parts/MSD-84741/
Your question and input are greatly appreciated.
Old 08-23-2012, 05:32 PM
Simple math....
683 CFM --- using 355 ci -- 7000 rpms -- mildly built motor.
Here's my real world take on it.... for the street -- the 650 is PLENTY.... if you're going to race and want WOT HP go with the 750
I prefer the throttle response of the smaller carb for 99% of most driving needs.
Old 08-23-2012, 05:34 PM
Shoulda put a caveat in there -- the CAM only makes a difference when it comes to IDLE QUALITY... some carbs are built for big azz cams and some are built for stockers. If you have a "duntov 30/30" kind of cam like the old 327/350hp --- I wouldn't factor that in to your choice. It's just not enough cam to mess with a big cam carb.
Old 08-23-2012, 05:36 PM
intocarss's Avatar
650 Cfm
Old 08-23-2012, 05:37 PM
.... and one more caveat.
Whatever you do -- stay clear of their "Avenger" POS useless crap of a carb.
Trust me on this one.
Old 08-23-2012, 06:40 PM
Sieg's Avatar
Thanks guys! The Air Gap RPM and 650 HP with mechanical secondaries, no choke, contoured venturi's, notched floats with jet extentions, and float bowls with additional baffling should be an improvement in tunability and a decent gain in mid to upper rpm over the Torker II and 650 VS Demon ..........I hope.
I doubt I'll regrete having a choke, they've been more of a pain than benefit on the last two carbs.
Old 08-23-2012, 07:31 PM
No need for a choke on a car like this... IMHO
Old 08-29-2012, 10:54 AM
alvin3a alvin3a is offline
Just curious why you say this... please tell us more
Alan
Old 08-29-2012, 12:09 PM
Alan
No point messing up this good thread with useless info -- but those carbs are just nothing more than a OEM replacement carb and not for replacements on a HP motor.
