Old 11-30-2012, 09:41 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Originally Posted by DOOM View Post
2.66 Is a done deal thanx to Todds expertise!! I got it all beefed up with all the goodies to handle a ''LITTLE'' more HP . Now all I have to do is get it American Powertrain has no Tremec cases ???? 6 weeks now.. Just called yesterday still nada!!!
I bought my close ratio magnum from D&D Driveline in Wixom, MI. I went to the Formula 43 open house back in October. D&D and Formula 43 are only about 20 miles a why from each other. I figured I could kill two birds with one stone since they are about 150 miles from me. I called D&D two days before heading to the open house and they had them on the shelf. They were great to deal with. If American Powertrain doesn't deliver give D&D a call. They told me Stielow's T56 is a stock off the shelf close ratio Magnum. I figure if his is holding up to 8xxhp I should be good.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 12-03-2012, 03:43 PM
DOOM's Avatar
DOOM DOOM is offline
Thanx Jason I'm only going to let this go on a couple of more weeks before it gets nasty... Then will be calling D&D
Mario
USCOLLISION
Old 12-07-2012, 12:07 PM
BHG's Avatar
BHG BHG is offline
Hey guys,
Any further insight on close or wide ratio 5 speed for a big block with 3.89's? Running 335/30/18 rear boots. Wide ratio seems to be the best choice.
Any one running a combo similar to this?
thanks,
Old 12-07-2012, 03:50 PM
DOOM's Avatar
BHG you should start a new thread so more guys can read what your asking.
Mario
USCOLLISION
Old 12-08-2012, 12:07 PM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by BHG View Post
Hey guys,
thanks,
Which trans are you referring to? The TKO 600? If not, what are the gear ratios?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 12-11-2012, 08:50 AM
BHG's Avatar
BHG BHG is offline
Thanks Doom & Flash68.
I am looking at Keislers new SS700. I think I've got it cased. Crunched some numbers regarding rpm and speed.
The gear ratios are as follows:
close ratio: 2.66, 1.78, 1.30, 1.0, choice of .68 or .84
wide ratio : 2.97, 2.07, 1.43, 1.0, choice of .68 or .84
Think I was wrong about the wide ratio, will now be going with the close ratio with the .68 for fifth gear. Better to bang around town, and still have a highway gear.
68 Camaro project. Shafiroff 540 BB, M9 trutrac 3.89's, Speedtech subframe, Ridetech suspension, DSE tubs...
Old 12-11-2012, 09:46 AM
JMitch19's Avatar
I'd do a search on keisler before you decide to spend your money with them.
Jason Mitchell
Old 12-11-2012, 11:23 AM
BHG's Avatar
BHG BHG is offline
Ok, I appreciate the heads up man. I'm not set on Keisler by any means. What company would you recommend for a similar tranny & driveshaft?
Sorry this thread has kinda gone sideways.
