Old 04-06-2006, 04:28 PM
comp-spec's Avatar
Blast that car and take it to the painter... or tell him to come over and scrape the crap off for free[/QUOTE]
Old 04-06-2006, 07:56 PM
Blake Foster's Avatar
You think thats funny do you
Thats what i swould tell him
Old 04-06-2006, 08:51 PM
Bill Howell Bill Howell is offline
Site Sponsor
Don't look like the same car I saw a couple months ago. I can not wait to see it finished.
Bill Howell
www.americanstreetcarseries.com
Old 04-07-2006, 09:00 AM
Hey Bill
How the hell are you???
yea it has come along way hasn't it
How are things going
i still need to talk to you about a few things i will pm you when i have more time
Old 04-07-2006, 09:21 AM
sinisterbodyman sinisterbodyman is offline
how many inches did you lower your car......look good
Old 04-07-2006, 09:23 AM
Site Sponsor
Don't forget to show off those hood hinges....
Bill Howell
Old 04-07-2006, 12:05 PM
The car uses Fatman 2" drop Spindles with Killer Customs Tublar Upper Control Arms for the best geometry and no upper Ball joint bind ( as i have seen is a major problem with the brand of upper arm we started with i would check yours if the car is low)
and QA1 adjusted all the way down.......... as for how much we lowered it i am juessing at 3 to 3.5
Old 04-10-2006, 04:26 PM
Nutsy Nutsy is offline
Blake,
Car is looking wicked! When can Bill and I come out and drool on it?
Trev
Old 04-10-2006, 05:25 PM
Did you run into the famous Fat Man steering arm to wheel interference yet?
Car is coming along very nice.
Tyler
Old 04-10-2006, 06:49 PM
We had changed to a Unisteer rack, and they supply arms that are a little shorter in length to increase the steering. we have 19" front wheels and YES we had to mill off 1/4" on the tie rod mounting surface and re taper the bore. and now there is about 3/16 clearance from the tie rod end to wheel. but that is also with an offset hub we built to move the wheel in 5/8 of an inch to reduce the scrub and give more inner wheel well clearance
Not a big deal
