Old 06-05-2013, 10:43 AM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Originally Posted by Che70velle View Post
Are they selling sheet metal, or are they selling parts to AMD. Most metal company's import from china/Taiwan. The material can be bought and imported most of the time cheaper than being bought here.
Next time I talk to Mark, I can ask questions.
The best iron ore is from the USA, not Taiwan. I have a co-worker (PhD) that used to work at the Bureau Mines, and the best material quality is in the USA.
Here is where China gets the Iron ore according to this report.
https://www.bimco.org/en/Reports/Mar...naIronOre.aspx
Anyway, it looks like you never seen a stamping press. That is a stamping plant, so AMD is importing parts from Taiwan. Really, it is the labor costs is the main reason that companies are moving out. I have worked in Tool & Die back in the late 1980's, so I do know a "little" about stamping process. Degree in Engineering as well.
I showed you a bill of lading, that is required by law on country that exports and imports.
Jeff
P.S. Golden Legion Automotive corp, is the producer for GoodMark. If you need a bill of lading, then shows several companies that deal with Golden Legion.
Old 06-06-2013, 09:23 AM
Che70velle's Avatar
You are correct, the best iron ore does come from America. I simply stated that you can purchase metal, in bulk, most of the time, cheaper from across the pond. And yes I have seen stamping presses before.
Thanks Dad!!
Old 06-07-2013, 10:34 AM
Firebird-Geek Firebird-Geek is offline
Originally Posted by Sparks67 View Post
Ok, I found where AMD buys the parts from and it is taiwan. The original Shipper is a company called Triplus.
Jeff
My rear full quarter panels came from AMD, and yes, the boxes say Triplus on them w/ AMD stickers. They are OK, but will need some work (Which I think most do). Not many choices for Firebird convertibles.
1967 Firebird Convertible
Jarrod
My Build:
https://lateral-g.net/forums/showthread.php4?t=32878
Old 06-21-2013, 07:26 PM
Sparks67's Avatar
I talked to Matt at Sled Alley, and he has to modify AMD to make them fit correctly. A friend of mine is an original owner of 67 Firebird convertible and he had the quarters replaced with Camaro NOS quarters in 1994, because he couldn't get any 67 Firebird convertible quarters.
Jeff
