Old 02-26-2016, 12:07 PM
DT69Cam DT69Cam is offline
Originally Posted by HPIcustoms View Post
DT69, I will do camaro brackets asap if you're interested. Just gotta get a camaro from a customer.
Sounds good to me !
69 Camaro Convertible (LS3/TKO in the works)
Old 02-26-2016, 12:14 PM
dontlifttoshift's Avatar
@HPI those tabs for the fuse box are awesome, I'll order some for the next time.
If I could make a suggestion on the throttle pedal bracket, slotting the lower two holes in an arc would allow the gas pedal to be adjustable and wouldn't take a whole lot of work on your end.
Cool Stuff!!
Donny
Old 02-27-2016, 01:21 AM
cjsgarage cjsgarage is offline
randy, I stripped the harness down, cut it to length, repinned it and sheathed it in nylon sheathing to get rid of the corrogated stuff. Came out nice, so I drooped part of the harness from the backside of the engine to the driver's side firewall bulkhead. Then I ran the power wires up the driver's inner fender/out fender gap to the fuse box that I mounted behind the driver's headlight.
the little droop part went under the brake master cylinder, and since the bay was black and the sheathing was black, it's hard to see.
I like wiring. No joke.
Old 02-27-2016, 05:41 PM
randy randy is offline
I built a bracket off of my DBW pedal. Sits really nice there and easy to get too
Old 01-14-2020, 11:20 AM
stan65 stan65 is offline
Digging up an old thread!
I'm looking for for a relay and socket that clips onto the GMPP Fuse box tabs that the mounts on page 2 of this thread are using.
Does anyone know what the tabs were used for originally?
Thanks,
Stan
The Following User Says Thank You to stan65 For This Useful Post:
marine15Z28 (12-01-2020)
  #26
Old 03-26-2021, 04:45 AM
130fe 130fe is offline
Thumbs up
Stan, just saw this and wanted to post it up for those that might still be looking for them.
https://www.summitracing.com/parts/sum-900485
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
The Following User Says Thank You to 130fe For This Useful Post:
dhutton (03-26-2021)
  #27
Old 03-26-2021, 05:03 AM
Nice, I couldn’t find them so I made my own. This is the only pics I have handy....
Old 03-26-2021, 05:20 AM
PM sent Stan.
Chris
1968 Camaro SS
LS3/T56
