Old 10-21-2013, 11:11 AM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
Dannmar here....
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
Old 10-21-2013, 11:15 AM
Revved's Avatar
Revved Revved is offline
Something to also consider if you might have the need is that some of them now offer portable 4 post lifts. I know Bendpak has a model that comes with 4 dollies you lower the table onto and it lifts the post making it portable.
Great advise on shopping accessories as well. If you are just looking for parking space basic is fine but if it is your only lift you will eventually want the ability to take off tires and do other work. You can buy jacks made for the hoist but last time I checked the Bendpak ones were around $750-$800 ish each if I remember correctly... You can also get pans that to sit under the table to protect cars parked underneath from drips. If you have a lowered vehicle you may also want to look at extended ramps so you aren't storing a set of 2x8's for extra ground clearance. Most manufacturers also offer convenience stations where you can plumb outlets and air chucks.
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
