Old 10-25-2013, 03:51 PM
Proforged Proforged is offline
Originally Posted by Regal454 View Post
Who makes the bronze replacement bushing? Are the Proforged idler arms currently made with the bronze bushing?
Our arms are not currently made with a bronze bushing. We are very interested in this, too - Carl...who makes that?
Zack Kanter
President
Proforged Chassis Parts
www.proforged.com
Tall Ball Joints, Tall Tie Rods, Billet Adjusting Sleeves, and Steering Linkage Kits for Musclecars
Old 10-25-2013, 08:41 PM
Rod P's Avatar
Rod P Rod P is offline
me too!! my car gets driven very hard!! I would interested in a HD version of what I have or a rebuildable design
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 10-25-2013, 08:44 PM
Sieg's Avatar
Sieg Sieg is offline
I was thinking Delrin but looked up the thermal properties and they appear to be on the low side for tight exhaust clearance with high loads: http://www.sdplastics.com/delrin/delrin[1].pdf
Old 10-28-2013, 06:53 PM
Sieg's Avatar
I removed the GM Pitman arm and installed the Moog K6099 replacement Pitman arm on the car today and the Moog arm compressed against the header as it was tightened to the frame. The OEM arm had just over .25" clearance.
A bronze replacement bushing for rebuilding the OEM arm would be real nice in my situation.
Doug's D368 headers, GM OEM motor mount perches, Moroso 62150 solid mounts.
Old 10-28-2013, 07:27 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is online now
Sure. Is it aftermarket?
It's a MOOG.
Scott from NJ
Old 10-28-2013, 10:57 PM
CarlC CarlC is offline
I made it on a lathe. It was a bit tricky getting the length just right so that the end cap did not over or under-preload the bushing/pin axially.
The grooves in the bore and face are for lubrication.
The cap was welded back on taking care to keep it seated square.
http:www.vaporworx.com
Old 10-28-2013, 11:01 PM
Sieg's Avatar
Carl - Was it a factory arm that you installed the bushing in?
Old 10-29-2013, 09:53 AM
Originally Posted by BonzoHansen View Post
It's a MOOG.
Great - shoot us an email with your address!
Zack Kanter
President
www.proforged.com
Old 10-29-2013, 08:38 PM
Moog replacement.
