Old 02-07-2014, 06:01 AM
dontlifttoshift's Avatar
3 Speeds? So not a GENIV unit?
Dash vents, the higher the better.
Donny
Old 02-08-2014, 06:21 PM
HIFLYR's Avatar
HIFLYR HIFLYR is offline
Nope gen II and stock looking car so only the mini vent in the upper dash.
Old 02-12-2014, 03:51 AM
Bmf5150 Bmf5150 is offline
I have heard from two different sources who has installed both systems that classic auto air cools better than the VA setup!!
Old 02-18-2014, 09:48 AM
http://www.pro-touring.com/threads/1...t-should-I-get
Old 02-18-2014, 01:15 PM
67Rally's Avatar
67Rally 67Rally is offline
Originally Posted by Bmf5150 View Post
Good info. Did you install the Classic Air?
Old 02-18-2014, 09:39 PM
No, but that's the one I'm getting
Old 02-18-2014, 10:15 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I need to check into Classic Air too. I need the coldest a/c. I live in Texas where the summers are hotter than hell....literally...no joke.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-01-2014, 10:38 PM
I read some where that restomod air is uses the classic auto air assembly???not sure if it is true or not
Old 06-02-2014, 05:25 AM
Its the same company so that wouldn't surprise me.
Donny
Old 06-02-2014, 10:58 AM
OBeer-WAN-Kenobi's Avatar
Just an update. I went with the Classic Auto Air system. I haven't' gotten it charged yet so can't comment on the cooling (although the heat will smoke me out of the car) but I can comment on the overall quality and installation.
First, a disclaimer: this may have been different if I would have ordered it directly from CAA instead of through a vendor.
If you are looking at this for a 1st gen Camaro, don't do what I did and tell them what your car was from the factory and what you are doing to it and expect them to send you what will work best for you. Why? Because if I would have known more about this system before I got it I would have changed some things.
For instance, I got the system for a small block Camaro without AC because that's what I have right? So, my heater core inlet and outlet were still right next to the head. To be honest, I'm not sure why that's even an option. If you are putting this in your car it's not going to look stock anyway so why in the heck do they even make one with the inlets/outlets in the small block location? They should just have the big block location or something like Vintage air where you put them in.
So, #1, don't buy the small block version, I can't see a point to it besides being more cramped, especially with the slightly wider LS block.
Next, the instructions suck. Everything doesn't seem to be in the right order (IMHO) and the pictures and explanations leave a lot to be desired. I found myself rereading the same paragraph several times in order to try to make sense out of it and still had trouble until I ignored the instructions in favor of the trial and error method.
The center louver's appearance leaves a bit to be desired At least mine did. The coarse part of the louver's texture is about right but it's way too shiny. Almost like the mold needs to be media blasted to dull it out. Mine also had some misalignment of the vents but CAA took care of that and is sending me new one.
Other than that (and actual cooling power which I haven't been able to test yet) the CAA unit is of fine quality and I really like the controller. I also like how the ECM works and where it can mount due to having long enough wires to find a good location for it. The ducts they give you are also plenty long enough to route it how you'd like and I had to trim pretty much all of mine. The hoses that come with it are complete where CAA knows the length (firewall to condenser for instance) and left long and only fitted with one end where you decide routing. Just trim it where you want it and bring it to the local autoparts store to have the end crimped on.
Bottom line:
So far, I'd say that I would order a CAA kit again with one caveat. I'd order it for a big block car or see if they have an option to place the "through firewall" hoses in a user defined location.
I'd also like to install a VA system and see the differences as there are a lot of features I like about them as well.
The reason I decided to go with the CAA kit initially is because I've read in quite a few places that it cools better. We'll see how it works when it's charged (and my radiator fans work through my PCM).
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
