Old 02-06-2016, 07:13 AM
Randy crick Randy crick is offline
Got zl1 seats mounted .Only modification had to do on front was cut notch in original floor support to were the zl1 seat would lock in then drilled the two holes in rear and mount.The back seat however was quite a task.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 02-08-2016, 01:33 PM
syborg tt's Avatar
Here is another one that I just found the other day. Looks like a really nice car and it's 4-sale. I would like to see more pics of the build and maybe who built the car.
http://www.garagescene.net/index.php?/category/485
marty-mj
Old 01-21-2019, 05:28 AM
dhutton dhutton is offline
Finally got these seats installed. It was extremely tight with the MCI console. Seats look a little odd because they are so tall but they are very comfortable. Driving position is great for me at 5’9”. A tilt wheel is essential. Probably wouldn’t do it again but there was no turning back.
Don
The Following 2 Users Say Thank You to dhutton For This Useful Post:
130fe (01-21-2019), slimjim (01-21-2019)
  #24
Old 01-22-2019, 12:59 PM
JON Q's Avatar
JON Q JON Q is offline
Hi Don, do you have any pics of what you had to modify either floor pan or seat rails if any? I have a set as well that will be using on my 69 Camaro.
Jon
Old 01-22-2019, 01:29 PM
slimjim's Avatar
slimjim slimjim is offline
Jon
I am running the standard SS seats but may upgrade to the recaros.
We notched the running boards, removed the original seat pans and mounted the seats as low possible.
NC
streamline 68 camaro
Build Thread here
Old 01-22-2019, 04:53 PM
I didn’t do anything this sophisticated. Just added some small extensions to the floor pans with correct mounting nut locations. I cut the locating features off the bottom of the tracks. I had to remove a skooch from the rear outside track to clear the seatbelt mounting bolt hole. One of my goals was to retain the stock mounting holes in the event that I could not get these to work.
Jim’s solution is superior but I think it would exclude the Morris three point belts I wanted to use. His method would work better with the TMI console.
Don
Old 01-22-2019, 05:09 PM
slimjim's Avatar
Don
My method was really a result of installing the 5th gen dash, trans tunnel and center console. something to keep in mind depending on what console you use.
NC
Build Thread here
