Old 03-16-2015, 04:02 PM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
I'll be buying one in a few weeks and this is what im looking at right now.
http://www.currentperformance.com/sh...y-and-bravada/
A man that's motivated will find a way.
PROJECT'S
1984 GMC swb truck
1972 Camaro
2013 GMC truck
Old 03-17-2015, 12:05 PM
jeremy30thz's Avatar
jeremy30thz jeremy30thz is offline
Originally Posted by XTRMEASURES View Post
Any Rad that fit in a s10 with a LS swap???
I sent you a PM
Old 04-04-2015, 11:31 AM
joeljet joeljet is offline
Default radiator
what kind of price am I looking at for a 73 firebird with a ls1 with fans? got any photos? thanx joel
Old 04-06-2015, 09:25 AM
Justin@EntropyRad Justin@EntropyRad is offline
Default '73 firebird Setup
Jeremy will be happy to get you a price on it!
Old 04-06-2015, 04:12 PM
PM sent
Old 04-07-2015, 07:41 AM
GrabberGT's Avatar
GrabberGT GrabberGT is offline
What do you have for those of us running small block fords?
Chris
Its not a Vega!!!!
Total Cost Involved - Total Control Products - Gateway Performance - Fatman - MaverickMan Carbon
Old 04-07-2015, 07:55 AM
What car? Auto trans?
Old 04-07-2015, 02:42 PM
GrabberGT's Avatar
Ford Maverick, 347, T5 trans.
Chris
Its not a Vega!!!!
Old 04-08-2015, 11:38 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Radiator for Bird
So reading the website it says no cross flows for Pontiac??
But the 73 has side tanks??
I have a 494 inch Mr-1 Pontiac Style block with Roland Racing heads
I have a wilson manifold -12 feeding all corners except the back which
goes back to the water pump... water pump is an electric mezerie
Hp is 755 + or - as we did change the cam to soften it up a little
Elect fan thru stock shroud which is marginal.. says 3000 cfm but??
Had my old 4 row rotted out last time and I thing it may
be shot or plugged.. over 25 years old and 9 motors now
5 speed and will use switches on each fan like on my other car
seems to work better for me not have auto plus I can cool
things down after a run in an autocross with the elect pump
and fan running on a hot day
Car is 180-200 most of the time (not a really hot day)
But when I push it for any length of time on the freeway
then 220 plus and climbing.. my guess not a fan issue
What you guys got to keep her cool???
Bob
Old 04-08-2015, 01:20 PM
Default Radiator setup for your 'bird
We can build just about anything in a Dual-Pass setup for you. The only "issue" with the DP setup leaves the hoses on passenger side a la LSx swap
This is our 68-77 GTO/LeMans radiator thats supports 900hp and flows 5600CFM:
Since it's for the for the 'bird chassis, you're looking at a similar design to this, but in a dual-pass or cross-flow with 1.25" tubes and giant fans
Both setups range $940-960 plus the ride. There will be a build time of ~2-3 weeks since completely custom-built.
Jeremy will happily order one from me for you!
