Old 12-11-2016, 06:59 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by tpichevy View Post
What did you end up doing? I have a 12 bolt 1970 camaro rear with Mark Williams c-clip eliminators and drums. Wanting to run disk brakes bad but having trouble finding some other then the non popular TA 12 bolt disk brakes setup. Does anyone know if the s10 disk brake swap could work?
Hello,
This https://lateral-g.net/forums/showthread.php4?t=52854 will bolt directly onto your GM rear. This set-up will eliminate your current c-clip axles/c-clip eliminator kit and convert you into a full blown floater rear. You also would be able to run any brake kit made for C5/C6 Corvettes (both OEM and aftermarket). Not cheap, but is THE BEST solution for GM rears.
Jay
Old 12-13-2016, 12:24 PM
Sonar Chief's Avatar
Hey I ended up selling the 12 bolt to a gentleman restoring a 69Z and I bought a Speedway Engineering 9" with Jay Miller's bolt on C6 ends.
Originally Posted by MillerBuilt View Post
Hello,
Jay
It is the best solution and that's the route I took, thanks for answering all my dumb questions!!!!
Michael
