Old 12-11-2014, 10:38 AM
economiser economiser is offline
from 9" to 11.75"
bit of a problem, but parts have been ordered
Old 12-13-2014, 01:12 PM
getting my rewiring looking stock
that mockup looks great
Old 12-13-2014, 01:16 PM
there is clearance between the Brembos and the Racelines!
Old 12-13-2014, 03:11 PM
Seems you're cruising right along! Nice job cleaning up all those electrons...
Old 12-15-2014, 09:50 AM
Thanks!
Old 12-17-2014, 11:37 AM
Old 12-20-2014, 09:50 AM
Yesterday I turned the car around to do some welding after all that butchery, but then I discovered what a hypocritical dumbarse I am. I set a fender in place, and realized I hadn't moved the crossmember back. The front wheels were way too far forward. Now I have to move everything back an inch, then mock it up. And even if that goes well, now I have this hassle of the steering linkage. Even at an inch I'll still have slightly more wheelbase, and positive caster, than stock. I seldom worry about looks, and I don't mind the idea of the wheels not being centered in the wells, but this needs corrected.
Old 12-23-2014, 12:53 PM
Old 01-15-2015, 09:49 AM
Not dead. In fact, just got the Moog CC877 springs assembled onto the struts, after a bit of modifying the springs.
Old 01-16-2015, 08:14 AM
I did a little trimming on the struts, the spring seat, but then when I tried to put the wheels on, the tire rubbed the spring. So I had to undo alot, turn the spring a quarter turn, then I felt I had to spot weld the tip of the coil to the spring seat. Pics to follow. Anyway, now the car rolls.
I need to get the engine and trans in the car, to free up some garage space, before making some custom brackets to mount the Brembo calipers.
