Old 01-10-2015, 06:36 AM
jlwdvm jlwdvm is offline
Stock Sub frame
Texas Speed 570hp LS3
T56 trans
Tru Turn
Holley Kit: 302 pan, ceramic 1.75" long tubes, cross member, motor mounts
Everything went together great...drive line angle at 3 degrees. I had to dimple a header tube on both sides due to inner tie rod interference. I also had to grind a very small amount off of a corner on the Tru Turn tie rod relocating bracket for oil pan clearance...mainly for piece of mind. I also had to go to a smaller power steering pulley to get extra space at the drivers upper A-arm.
Now to get the 275's to clear the inner fenders!
http://www.pro-touring.com/threads/1...ar-build/page4
Old 01-10-2015, 08:56 AM
130fe 130fe is offline
Thumbs up
Originally Posted by Carbo View Post
Hey Chris,
Did your mounts place the engine in the stock location as the SBC? I'm trying to accomplish what John did to Steve's car by reusing the TKO.
S&P said their mounts are stock location. Sent you a PM.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-10-2015, 09:24 AM
Carbo Carbo is offline
Got it Chris...thanks. PM replied.
