Closed Thread
Old 03-07-2016, 04:31 PM
Che70velle's Avatar
Good Lord would someone please buy this!!!!
Every two days or so, I try to justify why I need this!!
If anyone has ever priced super chargers, then you realize that THIS IS A STEAL!!!
It's like getting a Wegner front drive set up for free!
Thanks Dad!!
  #22
Old 03-21-2016, 07:00 AM
Sparks67's Avatar
Sparks67 Sparks67 is offline
I had several people interested in buying the supercharger setup, but so far no one is willing to pay for it.
  #23
Old 03-23-2016, 08:31 AM
Sparks67's Avatar
Supercharger is now on ebay, so you can start bidding for it.
http://www.ebay.com/itm/-/331810792677?
  #24
Old 03-23-2016, 05:56 PM
nuzzo nuzzo is offline
Smile
So is it just sc and front runner? I thought there was wiring computer coils and other stuff? If I can sell my bbc I am gonna go ls and I have always likes blowers......can that all work on a stock ls motor?
  #25
Old 03-23-2016, 06:20 PM
1nastyZ06 1nastyZ06 is offline
I'm just trying to understand why you changed from this killer blower and front runner setup to the LS9 blower and factory style front runner. This is a killer deal and I wanted it so bad but I really wanted to build a big cubic inch LS7 with nitrous.
But someone needs to jump on this. And for the last guy who asked about selling his BBC and working on any LS. It will not. You will need at least an LS2, LQ9, LQ4 block with a 4" bore in order to run the LS3 rectangular style head that this blower fits on. Or obviously you could just run an LS3. All the heads (all basically the same with slight differences in valves or cc sizes) listed by Jeff above will work on a 4" bore block and this blower.
69 Camaro - LS7 441ci ;wet sump, Custom cam, Port matched MSD intake, ported 90mm TB, Texas Speed PRC 285cc LS7 heads withBTR rockers. Tick built T56. Scott Mock subframe, TCI torque arm rear setup, C6 Z06 brakes, built ford 9" 3.73 gears, Trueforged 3pc Wheels. Lots more
  #26
Old 03-23-2016, 07:50 PM
Sparks67's Avatar
I changed the advertisement to be only the supercharger and pulley setup. I have other advertisement for the harness and coils. Everything is now listed on ebay, so you can bid for it. Yes, you can put it on stock LS3 engine.
v/r
Jeff
  #27
Old 03-23-2016, 08:40 PM
Sparks67's Avatar
I originally wanted an LS9 for my 67 RS Camaro, that I bought out of barn in 1983. I do seem to have two everything for my build, but I should have bought the 67 Convertible that was in that barn. You should have built an LS7 441 with a Supercharger, but you never have to worry about filing the bottle. The radiator core support to AutoRad is all custom one off piece. I came up with the design in about 10 minutes at Sled Alley Hot Rods. I had Matt build it to set off the Ring Brothers hood hinges. I have to post my own thread on the updates to my car soon.
Jeff
  #28
Old 03-24-2016, 09:53 AM
Hotrod1's Avatar
Hotrod1 Hotrod1 is offline
Jeff
What belt/pulley system is that?
  #29
Old 03-24-2016, 05:52 PM
Sparks67's Avatar
11 Rib Pulley.
  #30
Old 03-24-2016, 09:01 PM
Haha. Gonna be hard enough getting traction NA with the 441ci LS7. I can control the spray through 2nd gear and up and hopefully get the power to the ground. I could only imagine with this engine and a blower. If I was building the LS3 stroker still I would be all over this setup though. I still can't believe it hasn't sold. Have you tried Ls1tech?
Closed Thread
