Old 04-22-2015, 10:28 AM
jimmythehand jimmythehand is offline
Default LSA with speedtech subframe
I know there has been some discussion about having to notch subframes to accomodate accessory drives on the LSA. Has there been any definitive solutions to avoiding the notching and still retaining those accessories? Specifically related to Speetech subframe if possible...thanks.
Old 04-22-2015, 11:48 AM
cwylie cwylie is offline
Not with the stock lsa compressor. You may be able to fit a SD7B10 compressor but that would also depend on the motor mounts you use. I think their new subframe is being build to allow for a low mount compressor though.
Old 04-22-2015, 11:49 AM
I gave up on trying to fit it down low on the stock subframe with the holley motor mounts and bought the accessory drive from Concept One.
Old 04-22-2015, 02:47 PM
dhutton dhutton is offline
Concept One is a nice setup but sending the supercharger off to Lingenfelter for the pulley upgrade made it a no go for me. I got my compressor installed down low with a modified VA bracket to clear the mounts. Also needed the VA Sanden compressor with side exit ports instead of rear exit. It was not a Speedtech sub but something similar might work.
Don
Old 05-14-2015, 07:54 PM
alongfortheride alongfortheride is offline
Well here is an lsa engine with compressor mounted low in stock subframe
Old 05-14-2015, 08:23 PM
Don did you have to cut the sub frame to install it with your mount? Which accessory drive did you use with it?
Old 05-18-2015, 04:12 PM
ironworks's Avatar
Old 05-19-2015, 09:13 PM
GRob GRob is offline
Wegner has a setup under development.
Old 05-20-2015, 10:39 AM
Wegner does for an LSA?
Old 05-21-2015, 08:18 AM
Does anyone know anything about the setup from street and performance? It looks like from the picture on bottom left, that the a/c and alt are both relocated up, so notching would not be needed.
http://www.hotrodlane.cc/lsasetups.jpg
