Old 08-11-2015, 07:39 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
With a PSI harness you do not need a brake switch with a manual.
If you wired in a neutral safety or clutch switch it would not crank so thats not the problem.
When you first turn the key on you should hear the fuel pump run for a few seconds. That would indicate the fuel pump relay is working.
Then you need to determine if the ignition relay is working. The easiest way is to touch the relay and have someone turn key on to see if it clicks on.
The other common issue with not starting is the ground wires that attach to the head are either not connected or loose.
Old 08-11-2015, 09:16 AM
Swain's Avatar
Swain Swain is offline
Originally Posted by 79 Camaro View Post
If you hooked up the 12 volt switched to the original wire that runs to the coil and it was older style points ignition the coil wire will have a resistor built limiting voltage during run.
I've never heard of a brake light switch wired to the ECM when using a manual trans that would prevent it from starting. Only time I've seen it was to make the reverse lock out work like stock.
Try wiring the switched 12 volt to 12 volt constant just temporarily to see if it will fire. If it does disconnecting the wire will shut the computer down and shut off the engine.
From what I've read a bad cam sensor will not shut the engine down but a bad crank sensor will.
I ran a constant hot wire still nothing. Fans come on right away I heard that means theres a code. Shipping the ECU out to PSI today. This will be the best thing to do as they can program it to my specs.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 08-11-2015, 09:27 AM
Vega$69's Avatar
Did you pull codes?
I had the same issue with the fans and the harness/ECU I used on my LS7 Build from PSI. As I recall the fan set up was set wrong in the ECM. I have HP Tuner and was able to correct it.
Old 08-11-2015, 09:47 AM
cpd004's Avatar
cpd004 cpd004 is offline
One thing that can make the fans come on (provided the ECM is configured properly for all else) is not hooking up some sort of check engine light.
1971 Firebird
2017 SS
dhutton dhutton is offline
I recommend a low cost code scanner if you don't have one. Get one that lets you reset codes too. Very handy for these swaps.
Don
Old 08-11-2015, 10:06 AM
Swain's Avatar
Don
I have a scanner it will no link to ECU.
Tried everything lol.
Jason Swain
Old 08-11-2015, 10:08 AM
cpd004's Avatar
My scanner wouldn't link when a fuse blew on the PSi harness. Changed the fuse and everything worked.
1971 Firebird
2017 SS
Old 08-11-2015, 10:20 AM
Damn, you at least get A for effort..
Don
Old 08-11-2015, 10:28 AM
Swain's Avatar
Checked all the fuses 5 times or more ha. I wish it was simple something so simple. Prolly is
Jason Swain
Old 08-11-2015, 10:35 AM
What about all your grounds? How is everything grounded?
Don
