Old 07-05-2006, 06:25 PM
Steve1968LS2's Avatar
Originally Posted by clill
This whole subject is so outrageous I went and bought a oil filter to prove it. Here is a new AC delco PF 52. I cut it out of it's housing with a oil filter cutter. I can breath thru it with no problem. I poured oil in the center and before I could even fill it up the oil was running out thru the paper !!!!!!!!. Steve...Go duplicate what I just did !!! The factories have been using this system for 50 years because it works ! It takes no pressure for oil to pass thru the paper.
Hmmm.. the paper I was given couldn't be blown through.. maybe it was from the uber cheap filter..
I will forward this over to the guy that showed me the other paper and see what he has to say..
Interesting.. save the photos in case I do a story.. I can make you a star
Old 07-05-2006, 07:45 PM
clill's Avatar
clill clill is offline
Steve...Please do your own test so you can see just how easily oil passes thru the paper. You can order the filter cutter from Summit or just use a hack saw. I'm guessing you were trying to breath thru a flat tiny section of filter paper. Now spread out that whole filter paper and see just how much surface area there really is.
Old 07-05-2006, 08:39 PM
GTX's Avatar
GTX GTX is offline
Default This is what filter our Fleet used...Toilet paper!!
http://www.bypassfilter.com/photos.htm
Old 07-06-2006, 12:32 PM
Damn True's Avatar
Damn True Damn True is offline
Originally Posted by GTX
do you use scented "media"?
Old 07-06-2006, 04:31 PM
Blown353 Blown353 is offline
I like the quilted, more surface area for the oil and it's softer on my backside should I need to leave one on the side of the road.
1969 Chevelle
