Old 10-19-2015, 06:34 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Made a little progress today with a setback also........First.....Talked to the Edelbrock Tech guy today and was told ........"Gee".......You are the first one to have problems with the coils hitting the injectors......LOL........I sent him pictures and haven't heard a word since.........Next......the A/C compressor I had on the car with plans to move it down low fell apart as the compressor is too big to fit in that area available........Gonna have to go with the smaller SD-7 Compressor........So....I made a low compressor mount today just like I made for the LSA in the Chevelle.......Feeling good........Get home and put it on and something didn't look right.....LOL........Duhhhh!!!.......I assumed that the dedicated A/C drive belt position would be in the same place as the LSA.........LOL..........1 3/16" difference.........Guess I get to make another one tomorrow........Darn !!!!..........But......I did get the driver side Aluminum Edelbrock Coil cover clearance for the master cylinder and alternator brackets......Also took the radiator back out so I have some room to get the compressor fit and mounted in that lower position.......two steps backward and one step forward......
Old 10-19-2015, 07:53 PM
Jon69RagTop Jon69RagTop is offline
Default Looks good Ken
Show us a few more pics of your "clearance" work on the aluminum cover. That looks nice and tight from what I can see. What did you use for this?
Old 10-20-2015, 06:50 PM
kwhizz's Avatar
So........Continuing on with the A/C compressor mounting .........Again.......I made the same lower mount I made for the LSA engine and when installing it I found out the LS2 had different Belt spacing on the Balancer......I measured the difference and started over today on a revised version........LOL.....Again....this is guess work until you actually put it together and see those clearance issues.......I had the other version draw up in Solidworks so I revised it to be what I now thought it should be.......Here are some pic's of designing and making the brackets......Brought them home and other than some clearance issues with the upper piece it went together perfectly......
Old 10-23-2015, 06:24 AM
kwhizz's Avatar
Checked off a couple more things on the to do list.....When I first looked at the space available for the A/C compressor.....I thought "No Problem"......LOL.......well I had to go with the smaller SD7 and with that I have about a 1/2 " clearance all around, but....It is in and in it's final position.......No room for a tensioner so I'll just keep the turnbuckle in place.......Had to turn over the upper mount and modify it for clearance for the A/C fittings......but it's all good now........
The next thing to resolve was the Injector/Coil issue........Thru recommendations I bought a set of Holley valve covers than change the mounting position of the coils........Bingo......
Old 10-25-2015, 05:39 PM
130fe 130fe is offline
Ken, what is the round shaped object mounted on the pass side of the firewall?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 10-25-2015, 06:38 PM
kwhizz's Avatar
Part of the Alarm system...............
Ken
Old 10-27-2015, 05:57 AM
kwhizz's Avatar
A/C lines finished and installed.........The Heat Exchanger also showed up and needs to be mounted.......I also got the "O" ring tank seal that I needed to finish up the Tank installation (threw out the one that came with the pump with the box.......Duhhhhhh!!!)
Old 10-27-2015, 12:00 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Man I was just starting to think about getting into my blower setup - and your already almost done!
Those Holley valve covers look great! That sucks about all the custom work though. Is that heat exchanger for the blower intercooler - or for the AC?
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 10-27-2015, 03:34 PM
kwhizz's Avatar
Supercharger................
Old 10-27-2015, 03:35 PM
kwhizz's Avatar
One of the last things to do in the engine compartment is to get the heat exchanger mounted and lines run.......so I put the radiator back in for the last time so I can see where the interference issues will be
