Old 11-20-2015, 09:08 PM
I really love seeing this kind of quality work being done!
Old 11-21-2015, 08:18 AM
Beautiful job guys. Nice updates.
Old 11-23-2015, 03:56 PM
MetalWorksClassics's Avatar
MetalWorksClassics MetalWorksClassics is offline
Default Replacement panels
Originally Posted by awr68 View Post
Looking good guys! Let us know how the new panels fit.
Thanks for the input guys...the replacement panels actually worked out really nice...they are "Auto Metal Direct" brand.
Old 11-23-2015, 04:01 PM
Default Door skins
We replaced both door skins...good amount of work, but they came out really nice.
Old 11-23-2015, 09:03 PM
awr68's Avatar
awr68 awr68 is offline
Nicely done! Keep at it!
Tony
'68 Camaro
Old 11-25-2015, 11:44 AM
Thanks a lot...
Old 11-25-2015, 11:50 AM
Default Sheet metal replacement
With the doors done, we got busy replacing the rest of the 68's sheet metal.
Old 11-25-2015, 12:49 PM
Sonar Chief's Avatar
Question
That's quite a lot of work to resurrect this 68!
Question: how do you plan on keeping the rust from starting again? Seems from the pics that you guys are putting on the panels without etching primer ... is there a coating on the car now?
Just curious ... love the pics!
Michael
Old 11-25-2015, 03:22 PM
preston preston is offline
Along similar lines....
When you spot weld two panels together, the top side I can see is usually bare. Is the backside bare or do you have weld thru primer on it or do you leave the EDP coating on it ? and the 2nd panel below it, same question, is it bare, EDP, weld thru primer - Do you leave a coating on the back panel and then just scratch/drill it away through the welding hole ?
Love to see the skeleton dressed and looking good, I know from experience though what the photos don't show are hours of lining up panels in 3 dimensions.
Old 11-25-2015, 04:23 PM
Michael
Everything will get epoxy primed and seam sealed once the panels are in place, so no moisture will get in.
Glad you are enjoying the pics!!
