Old 11-04-2015, 05:49 PM
cpd004's Avatar
cpd004 cpd004 is offline
I appreciate all the help!
I've read a few different articles on breaker sizing (and my head is spinning)...it appears as though I would need a 150 amp breaker near the battery on it's way up to the starter. Does this sound correct?
Also, I'm thinking of going with a maxi fuse holder for the charge wire from the alternator. I think 8 gauge as suggested above will work just fine, but can't seem to find an appropriate fuse rating. The reason I'd like to go with a maxi fuse is that I can then use a maxi fuse block like what I have now and just a bigger one for the charge wire. My current one has 2 fuses...one that supplies power to the cars fuse panel and the other is for the electric fans.
Vince, I like what you did with the bulkhead down low and near the starter. It makes things nice and clean.
1971 Firebird
2017 SS
Old 11-04-2015, 06:32 PM
ilikeike's Avatar
ilikeike ilikeike is offline
Heres one way.
You don't have to use the relay on the starter curcuit,some just use a jumper at the starter.
[IMG][/IMG]
Old 11-05-2015, 08:25 AM
Vince@Meanstreets's Avatar
The 150 should be fine at the battery lead.
For the alternator I usually check full system loads but the maxi fuse I usually run a 70 amp.
8ga should be fine. It's rated for 75 amps. Doubt you output would see that.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 11-05-2015, 03:13 PM
cpd004's Avatar
One other question...what is the stud size on the breaker listed? Can't seem to find it anywhere.
1971 Firebird
2017 SS
Old 11-05-2015, 09:58 PM
MtotheIKEo MtotheIKEo is offline
1/4-28
http://www.cesco.com/b2c/product/Bus...-Breaker/28019
Old 11-08-2015, 11:01 AM
Originally Posted by MtotheIKEo View Post
You can buy blank 0/0 1/0 battery cable lugs and drill them to size.
Dealer for
NEVER FORGET -11
