Old 05-26-2016, 08:39 AM
flatoutz flatoutz is offline
Jay,
Thanks for your time and information.It looks like it will work for my application.I'm still in the building process with my car.So when the time comes,I'm seriously considering your kit.Very nice design.
Mike,
Old 05-26-2016, 05:36 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by flatoutz View Post
Jay,
Mike,
Sounds good Mike, thank you.
Old 05-26-2016, 10:45 PM
BuddyP's Avatar
BuddyP BuddyP is offline
I do want thank Jay for the great customer service and getting the parts around to me in time for the Midwest Musclecar Challenge. Very pleased so far with this kit! As Jay noted, I had consistent brake pedal feel throughout the day. No pad knockback detected.
Buddy P
MI/IN border
http://i97.photobucket.com/albums/l2...ps528d6c8b.jpg
Old 06-01-2016, 08:08 PM
Buddy,
Very happy to have been able to help. Thank you for the kind words and your support!
Jay
Old 06-04-2016, 09:31 AM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Do you have any pics of the completed install on the car?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 06-05-2016, 03:33 PM
Hi Steve,
I will have some soon and will post up a few. Anything in particular you are looking for?
Jay
Old 06-06-2016, 10:43 AM
RoadRace Elco's Avatar
RoadRace Elco RoadRace Elco is offline
Default I am interested
please let me know when ready for sale?
1966 El Camino
383 500hp at flywheel
Keisler SS700 5 speed
Mass-Flow Injection
12 Bolt 3:73
Speed Tech full suspension
Ride Tech Coil Overs
Rushforth 18's
Wilwood 6 piston with 14" rotors
Old 06-06-2016, 07:10 PM
Next batch is heading to zinc/anodize this Thursday. Will have multiple sets in stock and ready to ship next Thursday.
Please note, axles take approx. 3 weeks from the time that your order is placed (you will need to also provide necessary measurements to confirm correct axle lengths).
Let me know if you need any other details.
Jay
Old 06-22-2016, 03:29 PM
Jay,
When installing the system on the backing plate.Are you cutting the axle tube flush with the flange and what size are those bolts?
Mike,
Old 06-22-2016, 08:24 PM
Default 12 Bolt Kit - Flange/End Prep
Jay,
Mike,
Hi Mike,
Hope this helps. I have pictured below the required prep and can be done with basic hand tools, obviously you can utilize many different power tools to accomplish the same thing in a matter of minutes. For purposes of illustration I prepared my end in a vise, however this work can be done exactly the same while installed under your car.Oh, the adaptor bolts, or optional ARP studs are 3/8"....
With your existing axles & brakes removed......
Place a rag or similar inside the axle tube to keep debris from entering while performing the prep work
Cut excess axle tube at edge of factory parking brake dust shield register
Tube end removed. The remaining factory dust shield register will now locate the C6/C7 Adaptor centric to the diff/axle tube
Clean up cut with file
Chuck up the included step-bit into your powered or cordless drill
A few squirts of WD-40 at each of the (4) holes
With included step bit, proceed to drill out each existing 3/8" hole to 1/2". These are now ready to accept the 1/2" bosses that protrude from the C6/C7 Adaptor that help locate/strengthen the system
That's it, you are now ready to install your kit!
Let me know if you have any other questions.
Jay
