Old 05-15-2016, 04:14 PM
vstol vstol is offline
Originally Posted by dhutton View Post
What temperature sensor is your engine controller using? Are you using the GM controller?
Quite often guys use two sensors, one in each head.
Don
gotcha
Old 05-15-2016, 05:08 PM
Well I checked even further about the gauge and on Auto Meter's web site they list the same symptoms I was having to a bad ground. Long story short it is a bad ground. I changed the ground and the gauge stayed at 210 while the water was boiling. Thanks for all your help, I will know tomorrow or so when I crank it back up.
Note to Badazz I run the sensor on the ps side in the rear as well.
http://www.corvetteforum.com/forums/...ica-kinda.html
