Old 08-09-2016, 08:39 AM
Evan Iroc-Z Evan Iroc-Z is offline
[ youtube ] {enter everything after the v=} [ /youtube ]
Take out the spaces between all the brackets and you are all set.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 08-10-2016, 12:34 PM
warhawkchevelle warhawkchevelle is offline
Well, time flies by and plans change.
Decided to mini-tub the car, found another bad repair in the trunkbottom.
Old 08-10-2016, 07:19 PM
Centerforce's Avatar
Centerforce Centerforce is offline
We love seeing how far the muscle car passion extends beyond here in the states! Car looks great so far and were digging the blue!
Old 08-10-2016, 11:40 PM
Thank you very much!
This past winter I got some parts to the car.
A new TKO600 for the LS
Hydraulic clutch conversion
Manual centerconsole
New wiring.
Old 10-13-2016, 12:24 PM
Long time no see.
Been real busy at work but gonna get going on the car more from now on.
The engine complete except complete heads, my new ones are still at the machineshop. Had to redo all valve seats and get retainers in correct offset for my springs.
Got my Speedtech chassis brace kit last weekend and a set of 335/30-18 tires.
Im going DSE speed 3 kit, just need to save a bit more money .
How wide tires can I run in the front?
Reshaping innerfenders isnt a problem, just curious if I need to do any mods on the frame in the front also.
Would like to run 275 at least.
Old 10-29-2016, 09:54 AM
Made some progress today!
Old 10-29-2016, 01:14 PM
minendrews68 minendrews68 is offline
Very nice! All of it. Where in Sweden?
Old 10-29-2016, 07:33 PM
Nice load of parts. The motor looks good.
Old 10-29-2016, 11:46 PM
Thanks guys!
I live in med Sweden, in Dalarna.
A small town called Malung.
Waiting for the snow to come now.
Yeah, the motor should give plenty of power.
The specs are:
Warhawk LS7X block and heads.
Callies 4.00" crank.
Callies rods.
Wiseco 4.155 Pistons. 8:5 compression. Gonna run E85.
Bullet custom solid roller cam. .696 lift I believe.
Isky bushinglifters.
Crower shaft mount rockers.
All Manley parts in the heads, fullported also.
Holley hi-Rise manifold, looking to get a lower later on.
Holley injectors and TB, dominator efi.
Aeromotive beltdriven fuelpump.
Holley acc drive.
Old 10-30-2016, 07:14 PM
A few years ago I was in Gothenburg for about eight days for work. Man I loved that town, the architecture was astounding. Even took a ride through town out to the bay through the canal.
