Old 10-17-2016, 08:26 AM
rickpaw rickpaw is offline
How about Earl's new vapor guard hose? I'm thinking about redoing my flex lines this winter.
https://www.holley.com/products/plum...arts/751066ERL
Tu Ho
Old 10-17-2016, 09:12 AM
jlwdvm jlwdvm is offline
I flipped my rail and used PTFE line and fittings from plumbingmonkey.com from the tank to the rail. The line has since been secured to the firewall with a little slack to compensate for motor movement.
http://www.pro-touring.com/threads/1...ar-build/page7
Old 10-17-2016, 11:17 AM
dhutton dhutton is offline
Nice OEM look. I like it. Thanks!
Don
Old 10-18-2016, 12:08 AM
gnx7's Avatar
gnx7 gnx7 is offline
I have a local place that makes hydraulic hose and he is an expert brazer.... he could cut the end off of that rail and make any radius bend you need.
This may be hard to see... however it is a stock fuel rail being fed from the back driver side with -10AN fitting brazed on.... then the original feed is actually the return. There was also an additional crossover tube added..... to the quick glance it looks stock... but it does support 1400hp+. This is my other RX-7..... 88mm turbo LS9 1/2 mile shootout car. Does mid 190's with total lack of traction.
Old 10-30-2016, 12:38 PM
Default Happy with this
Got he Russell 90 fitting that's threaded very nice like how it ended up
Old 10-30-2016, 02:50 PM
DT69Cam DT69Cam is offline
Which 90* part# did you use ?? Thx
69 Camaro Convertible (LS3/TKO in the works)
Old 10-30-2016, 05:58 PM
Russell 611223 Hose End
Old 10-31-2016, 01:39 PM
Thx!
