Old 11-19-2016, 04:47 AM
paulk68 paulk68 is offline
Default thoughts
so I am getting close on my wheels and tires and I was wondering after lots of reading and emailing people, I am still finding a lot of rubbing issues with the ridetech tru turn even on 18x9 18x9.5 wheels and a 265 tires. As my car will be 99% street driven and I do not want to cut my inner fenders. Will will a 255/40 front tire work with a 315/30 rear?
here are some measurements from falken
255/40R18 95W 28233844 9.0 8.5 - 10.0 25.9 10.3 794 9.4 8 28 51 1521 BLT -
315/30R18 98W 28233848 11.0 10.5 - 11.5 25.5 12.6 813 11.7 8 32 51 1653 BLT -
Old 11-19-2016, 04:54 AM
dhutton dhutton is offline
Paul it looks like that front tire is taller than the rear. Not sure you want that...
I just put 255/40R18 on the 69 I am building for my wife and they look fine. 8.5" wheel with 5.5 backspacing and Tru-turn.
Don
Old 11-19-2016, 05:40 AM
Don
Thank you Don, I see that height difference now as well thank you, back to searching.
Old 11-19-2016, 05:48 AM
Maybe go with 255/35 up front.
Don
Old 11-23-2016, 03:48 AM
so in in effort to keep in a 18" rear wheel what if I dropped down to this
255/35ZR18
(94Y) XL
300 AA A 1,477 lbs. 50 psi 10/32" 25 lbs. 8.5-10" 9" 10.2" 9.5" 25" 832 US
295/35ZR18
(103Y) XL
300 AA A 1,929 lbs. 50 psi 10/32" 28 lbs. 10-11.5" 10.5" 11.9" 10.8" 26.1" 797 FR
how does a 295/35/18 look on a 18x11 wheel?
Old 11-23-2016, 05:18 AM
How about this:
http://www.tirerack.com/tires/tires....omCompare1=yes
Don
Old 11-23-2016, 08:23 PM
Musclerodz's Avatar
I just finished a 67 Camaro with full ridetech suspension, tru-turn, with forgelines and 265/35-18 bfg rival up front, no rubbing. I am running 1 degree of negative camber as well.
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-23-2016, 08:59 PM
69Camaro's Avatar
69Camaro 69Camaro is offline
I'm ordering Forgeline GA3's very soon for my 69 Camaro with tru-turn and the Ridetech level 2 suspension. What backspacing and wheel size did you use? What brake package?
Thanks, Jayson
Old 11-23-2016, 10:22 PM
Musclerodz's Avatar
Thanks, Jayson
18x9 with 6.125 bs I think. Have to double check. Wilwood 14" aero brakes. I can quote all of it if you wish. I am direct top level dealer with most all the manufacturers including Ridetech, Wilwood and Forgeline.
Mike Redpath
facebook page
Old 11-24-2016, 03:08 AM
ugh I was all set on a 5.5 front back spacing per ridetech recommendation. seeing 6.125 makes me rethink it all. I am running the baer pro + brakes.
