Old 06-27-2017, 01:11 PM
Ben@SpeedTech's Avatar
With the taller T56 trans and the ExtReme subframe being designed to give you optimum low ride height to help be sure to have the correct driveline angle with plenty of room for suspension compression we have available a pre bent full length tunnel cover kit. This kit comes in 3 pieces and is easy to install. As with other builds truck bed liner is sprayed on the underside of the floor pan. More progress coming...
-Ben, Creative Director
Old 06-27-2017, 03:33 PM
1965_SS's Avatar
1965_SS 1965_SS is offline
Looks great Ben!
_________
1965 Chevelle SS
Project Build
Old 07-18-2017, 11:26 AM
Thanks Todd!
Continuing with the body work, Like the door skins it was easier and faster to replace sheetmetal rather than dealing with rust removal and panel repair so the front clip was also replaced new. In the process the front marker lights wre deleted. After everything was smoothed and blocked out a fresh coat of white epoxy primer was laid down.
Old 07-20-2017, 03:19 PM
With the black portions such as the firewall painted, the front suspension and drivetrain install got under way. Nestled between our ExtReme subframe's rails is a 525 hp LS3 GM crate engine. Smooth power with plug and play and a warranty, works out great for us and the customer.
Old 07-20-2017, 06:02 PM
cpd004's Avatar
cpd004 cpd004 is offline
Are the brake line tabs already on the subframe as it ships or are these customer added?
Also, what kind of clips do you use to retain the line to the frame?
1971 Firebird
2017 SS
Old 07-20-2017, 07:41 PM
Build-It-Break-it's Avatar
I'm pretty sure they're added Cuz my subframe doesn't have them
Ahmad B
Old 07-25-2017, 10:33 AM
Yes the tabs come prewelded in place now.
With the subframe and engine in place we turned attention to installing our rear Torque Arm system. Dutchman preps our 9" axles with a Tru-Trac center, gears of the customer's choice and our brackets all welded in place. In this case Charles wanted 4 piston Wilwoods out back and he opted for Viking Crusader autoX valved shocks.
Old 07-27-2017, 10:37 AM
More suspension and exhaust pics...
Old 07-27-2017, 01:20 PM
LanceL LanceL is offline
What transmission bracket is that? Is that a speedtech piece?
Old 07-28-2017, 09:40 AM
Blake Foster's Avatar
yes that is the NEW now OLD Extreme X member already been updated and replaced
Blake Foster
www.speedtechperformance.com
