Old 03-05-2017, 07:51 PM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
Default Remote oil filter location, any suggestions should be great.
I'm building a 1970 Camaro and I'm running an ATS oil pan with remote oil filter. I've been all over the car and so far have only been able to fit it on the drivers side radiator support. It seems like the shortest, most secure spot I can find.
Would there be any down side, to me mounting it here??
Any comments would be great!
Thanks,
Sandro
Old 03-05-2017, 11:28 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
I would suggest referring to Blake or Ben at Speedtech Performance . Their oil pan comes with remote oil filter kit and have seen them installed in a different location.
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 03-06-2017, 01:10 AM
I actually know them pretty good! I spoke with Rodger at speed tech and they usually install their remote oil on the front portion of the drivers side frame rail. Im running the stock sub frame so my steering assembly and sway bar takes up that whole area.
I was concerned with how far and the height of my location compared to the motor. I know its always best to keep it closer to the motor, but on my car it will be really hard to locate it elsewhere. I'm hoping there's no reason I can't keep it there.
Thanks, Sandro
Old 03-06-2017, 09:15 PM
Brewtal66 Brewtal66 is offline
My only thought is that every time you change the filter it's going to make a mess. That would be my biggest concern when doing a remote mount.
Editor, Lateral-G
[email protected]
Old 03-06-2017, 10:05 PM
Yeah, I had the same though. Lol
If I put it there I'll make sure I leave enough room to put a rug under it when I change the oil filter.
Old 03-07-2017, 03:39 AM
72Z/28's Avatar
That was the main reason for getting rid of my Milodon oil pan and going with Autokraft oil pan which has spin on type oil filter. Besides, you would get rid of extra plumbing required for the remote oil filter.
72 Camaro RS:SOLD
68 Camaro:
Old 03-07-2017, 08:29 AM
Blake Foster's Avatar
what about on the outside of the frame horn up by the bumper bracket. i think keeping it low would be better.
plus easier to drain with less mess.
maybe cut a hole in the inner fender to mount it high enough for the hoses to come over the top of the frame and into the filter mount.
Blake Foster
www.speedtechperformance.com
Old 03-14-2017, 07:26 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
My first thought as well. Do you have room to mount it in front of the radiator support? Could route the lines through the support and mount it down by the frame horn in front of the rad support?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
