Old 05-15-2017, 07:59 PM
JKnight JKnight is offline
I've personally encountered two bad Wilwood master cylinders (brand new) and heard of many others that just won't ever bleed out. All were exchanged for another that worked, but I have little confidence in them. I'd bet that a different MC with the same bench bleed process you used would get a good pedal.
Old 05-16-2017, 03:13 AM
vstol vstol is offline
Thanks this is my second MC from them. I will give it one more time
Old 05-16-2017, 07:15 PM
Oh, geeze, didn't realize that. Was the first one bad as well? Similar issues?
Old 05-17-2017, 02:53 AM
The first one would not seal at the rear fittings and I went through 3 brake lines and still leaked (wept) at the fitting.
Old 05-28-2017, 03:55 PM
ok bled the heck out this MC and no air so I will reverse bleed the system tomorrow.
Old 05-28-2017, 05:27 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
im going to buy stock in brake fluid. hopefully reverse bleeding it finally works. may have to go with a nice rusty gm master cylinder if it doesnt work.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 05-28-2017, 06:19 PM
Well, sounds promising. I used a cheapo CPP master and was pleasantly shocked at how quickly the system bled out. Sounds like getting a master with no issues is going to be the key to your system working out.
Old 05-29-2017, 05:39 AM
was it manual or assisted?
Old 05-29-2017, 11:34 AM
I have power brakes, vacuum assisted. Bled using the old pump pump hold method, engine off obviously.
Old 05-30-2017, 06:12 AM
I didn't go back to read the whole thread but HOPE that you bench bleed these Masters before installing --- it's a critical step.
