Old 08-23-2006, 07:17 AM
BThibodeaux BThibodeaux is offline
Originally Posted by XTRMEASURES
how much are factory kicks
i might see about getting some to play around with it
The non-A/C versions are only about $50 each from NPD.
Old 08-23-2006, 07:23 AM
Originally Posted by rockdogz
I've read about doing 'glass on plastic - you have to drill holes in it and glass both sides to attach them... I'm almost ready to work on the kicks. I have some of those baffles - do you think they will provide enough protection for the rear of the speaker? I'm debating whether to just make a whole fiberglass enclosure to seal them in. I'll be mounting the speakers behind the kick panel vents to test the sound and see if I really need to angle them or not.
I like the idea of drilling several holes and glassing both sides. I may try that on my current build. Thanks.
A fiberglass encloseure would probably be overkill, but that is your call. The baffles held up fine for me. For a little added insurance, you could always double them up via gluing 2 together. Use a strong sealer/glue like Shoe Goo to seal the edges to the car.
