Old 02-03-2018, 07:16 PM
76TA 76TA is offline
Old 02-03-2018, 10:37 PM
Decided to have a dedicated reply for this, but as you can see I decided to use the sub frame connectors I was running previously instead of the DSE connectors. The DSE connectors are a nice product/kit.
That said, I have the DSE connectors in their original box. They are for sale. Feel free to PM me.
Old 02-04-2018, 07:38 AM
Looks great! I'd consider painting the out tie rods before they rust so they continue to look great along with all the other pieces.
Old 02-04-2018, 08:40 AM
That’s a nice heads up. I’ll make sure I do that here pretty soon. Just picked up 4 1-ton wheel dollies from Harbor Freight so it’s easier to move her around the shop. Shouldn’t be too much trouble shooting them.
Next up is getting a replacement outer cowl panel for the drivers side. Tracked one down in AZ for 225 + shipping.
DSE steering coupler is next
That’ll be it until the summer/fall.
Old 02-04-2018, 09:01 AM
syborg tt's Avatar
Looks great and I am looking forward to more updates.
Sent from my iPad using Tapatalk
marty-mj
Old 02-21-2018, 01:40 PM
Worked with Tanks Inc. Picked up their EFI tank kit for 74-78 Firebirds.
Part Numbers Below:
- TAN-GML - Fuel Tank Sending Unit GM 1965 & UP Type 5 Hole Design - 90 Ohm support
- ST47 - 1974-81 Camaro / Firebird Gas Tank Straps
- GPA-6 - High Performance Fuel Pump Module - 400 Liters Per Hour - Supports 500 - 1000hp.
- TM203-T - 1974-77 Camaro and 1974-78 Firebird EFI Gas Tank
Old 02-22-2018, 10:31 AM
I'm using a Tank Inc's tank on my TA as well. Works great. Just be sure to run a good ground out to the tank from the chassis.
Old 02-22-2018, 01:24 PM
syborg tt's Avatar
When I switch to the Atomic EFI I will be running one of these tanks.
ps I forwarded this link to Ty as he is also going EFI
marty-mj
Old 02-23-2018, 06:34 AM
Total cost was about $670 + shipping. But that was with their top of the line pump. There are three options available depending on your hp.
Compared to a $800 fuel cell; I just couldn't rationalize the over the head cost difference between the two.
Old 02-26-2018, 01:47 PM
syborg tt's Avatar
That is not bad at all and I originally was going to use a fuel cell but then I found out they don't like to have gas sit in the bladders over the winter. Plus you have to replace them frequently.
marty-mj
