Old 02-11-2019, 06:59 PM
rideordie28 rideordie28 is offline
Default Rats nest and sound deadening gone
there isnt a wire left in the car and dry ice to remove old sound mat
Gm Performance Engineer
my views are that of my own and not GM
69 pro touring camaro - Agent orange
2019 Z06 corvette
The Following User Says Thank You to rideordie28 For This Useful Post:
syborg tt (03-30-2019)
  #22
Old 02-13-2019, 12:08 AM
Default Bad news
Upon further stripping of the old sound mat I have found some small rust holes in the passenger foot well. Since I have to patch an older poor mans patch in the trans tunnel I’ll be cutting the bad out and replacing that as well
2019 Z06 corvette
  #23
Old 02-13-2019, 09:26 AM
WILWAXU WILWAXU is offline
Thumbs up
First I've seen of the dry ice "trick". Something to store in the memory bank Thanks!
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
The Following User Says Thank You to WILWAXU For This Useful Post:
  #24
Old 02-13-2019, 09:42 AM
I probably don’t have to tell you this but there are footwell pan pieces available and they’re cheap — most all of these cars collected moisture in these areas.... and need them. And You don’t need to use the whole piece — I buy them and cut the part I need and stitch it in... Bam! Done.
The Following User Says Thank You to GregWeld For This Useful Post:
  #25
Old 02-13-2019, 11:30 PM
Default It works
It works well. Let sit for like 10 min. Use a hammer to break it up and scrap with a stiff putty knife
2019 Z06 corvette
WILWAXU (02-14-2019)
  #26
Old 03-24-2019, 08:51 PM
Default rust issues found and fixed
in removing most of the old sound mat i found that the old owner used fiberglass and bondo to fill the floors. they where rotted out. for a guy who replaced every exterior panel to no replace the floors in interesting. but all 4 floor pans and the trans tunnel have been replaced and i can now start building this car.
2019 Z06 corvette
  #27
Old 03-24-2019, 09:38 PM
Don’t forget to seam seal all of that!
Old 03-24-2019, 10:44 PM
Default seamer for days
ya i didnt forget. i like paint down on exposed metal before i seal it. thats tomorrow task. lots of time sealing
2019 Z06 corvette
syborg tt (02-09-2023)
  #29
Old 03-28-2019, 09:44 PM
Default finally had some time
Finally had some time to work on the car. now that all the panels are replaced sealer on the car and dyna mat installed on the front i am now working on the new harness, steering shaft, pedals, brake system and vintage air kit. and my motor finally is shipping!!!!!
2019 Z06 corvette
The Following 2 Users Say Thank You to rideordie28 For This Useful Post:
syborg tt (03-30-2019), WILWAXU (03-29-2019)
  #30
Old 03-29-2019, 10:31 AM
ur-n-8 ur-n-8 is offline
FYI. The Fusor company makes a (DTM) direct to metal seam sealer. It gives you the option to seam seal on bare metal or over primer like you are. Sometimes it's a nice option. It comes in beige or black # 800DTM or 803DTM respectively.
The Following User Says Thank You to ur-n-8 For This Useful Post:
